07-28-2010, 12:55 PM | #1 |
Sway bar ideas?
Im looking for a sway bar for my 66.
It will be bagged, with tubular lowers. The lowers I have, have no provisions for a sway bar or shocks yet. I wanted to see what end-link style sway bar people are using since a stock one wont. I've seen the brothers one, and CPP carries one, but maybe one off a newer truck would work? |
07-28-2010, 02:01 PM | #2 |
Re: Sway bar ideas?
We offer two different bars that will work for you... 1.125" OD $225 shipped; 1.25" OD $250 shipped. Both come powdercoated black with all hardware.
Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
07-28-2010, 04:30 PM | #3 |
Laid Lo
Re: Sway bar ideas?
I've got the CPP HD one. Looks great, easy install, think it was about $125 with all the hardware. I've got tube LCAs too and my truck didn't have a factory bar.
Grind off 2 rivets off the crossmember and replace with bolts. Weld in tab on LCAs. Bolt up bar Enjoy.
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
07-28-2010, 04:38 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Sway bar ideas?
the 65-72 ( i think) have one with 4 mounts similar, the newer trucks ( 73-87) have them with the end links. I am not sure about the sizes of them, but have heard a 3/4 ton from the 66-72 range are larger than half ton
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 07-28-2010 at 04:39 PM. |
07-28-2010, 06:24 PM | #5 | |
Re: Sway bar ideas?
Aftermarket bars can come either way: the shell/bushing combo or a mix (shell/bushings @ the frame; end-link/bushings @ the a-arm).
07-28-2010, 07:03 PM | #6 |
Jesse
Re: Sway bar ideas?
I have the Porterbuilt 1.125"OD swaybar and i can raise it all the way up and lay it out with no binding issues. It was an easy install also.
