Lokar shift cable linkage
I bought the lokar cable linkage for my 85 c10, I have a 4l60e in it and I wanted to see if anyone else has used this lokar setup and how they mounted it on the steering column. pics would be best!!
Re: Lokar shift cable linkage
in for pics
1979 c30 3+3 dually 1946 GMC |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Was it originally an auto or manual? Did yours not come with instructions? I will see if I can find the instructions for mine tonight if it will help you. Also, you can use the stock auto shifter linkge from the TH350 on the 4l60e.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Yeah mine came with instructions and I put it all together but for some reason the angle of mine snapped the end of the cable where the threads are. The angle the instructions give to put the extension on the column is impossible because it will go into the firewall. So i tried a different angle but since I broke it the first time now I am waiting for the replacement. Its been fun! not.
#5 | |
My build thread. Boy what did i get myself into! Last edited by draggin86; 02-09-2011 at 02:21 AM. |
and he isnt using that billet swivel holder piece that is saposed to clamp over the column either.... bet you a dollar he cant go from first to park and back again.
I actually have the same lokar shift cable and same set up with the 4l60e and I can go all the way to first no problem! Ill give you my address so you can send me that dollaR!!
i need that shiznit...i am needing a linkage for my 4l60e in my 84...what are the part numbers?
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330 84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic 10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic |
sharp as a marble
![]() Join Date: Jan 2007
If you bought this type, It need to go on the left side of the column, Not thr engine side. The cable will also need to be mounted to the trans from the rear of the trans.
http://lokar.com/interior_pages/prod...tlink2_rot.jpg |
