07-28-2010, 06:39 PM | #1 |
Need help asap
Well i got the big block in my truck got everything bolted and went to start it for the first time and i barely got it running.wat i mean by this is that the starter was dragging a lot.got the engine running for like 5 minutes at 2k rpms and everything was good, good oil pressure,temp wasnt dat hot,no unusual sounds at least that i could hear over the exhaust.and then the throttle came loose(i didnt have it hooked up) and the engine died. After this i tried to get the engine running again it would barely turn over so i thought it was the battery.got a fully charged battery and the same thing.went to turn the crank over by hand and is extremely tight even with the plugs out i can barely turn it over.my question is should it be this tight?the engine is a complete rebuild.i have asked several guys and they say dat is normal for it to be this tight,i just dont want to mess anything up.
07-28-2010, 07:50 PM | #2 |
Re: Need help asap
With the plugs out it should not have that ridiculously tight. The starter should have no issue turning it over especially with the plugs out. Timing being too far advanced will make it drag trying to start the engine but will have no effect with the plugs out. Did you assemble the engine? Did the crank spin freely before the rods and pistons were installed?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
07-28-2010, 08:14 PM | #3 | |
Re: Need help asap
07-28-2010, 10:47 PM | #4 |
Re: Need help asap
No. Valves would not cause it to have a hard time turning over by hand when the plugs are out.
When you pull the plugs, will the starter turn it over then? Did you prime the motor through the distributor hole before firing it up? How fast did you get oil pressure? What was the oil pressure reading when you fired it? Have you drained the oil to see what it looks like? (might be a good idea)
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 07-28-2010 at 10:47 PM. |
07-28-2010, 11:10 PM | #5 | ||
Re: Need help asap
2yes I primed the engine through distributor hole before starting until I had oil coming out of all pushrods. 3I had oil pressure as soon as I started to crank engine 4I think oil pressure was like at 60 at 2k rpms 5no I haven't drained the oil yet but I did check it on the dipstick and it was clean with no shavings in it |
07-29-2010, 01:13 AM | #6 |
Re: Need help asap
you typically won't find shavings on a dipstick, but will in the filter if you cut it open and in the oil when drained. I'd look in both places.
I assume you have a tq wrench. If you set it to 75lbs, will the motor spin before setting it off with the plugs out? If so, how low can you go before clicking it. This will give us all a real idea of how hard it is to turn.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 07-29-2010 at 01:13 AM. |
07-29-2010, 08:44 AM | #7 | |
Re: Need help asap
07-29-2010, 04:21 PM | #8 |
Re: Need help asap
Make sure to drain the oil too. Some cheaper filters are known to have the bypass stick open. If there is any shavings going through the oil system, the filter won't stop them if that bypass is stuck open. Then all of them will be in the pan and through out the motor, making matters worse.
If you can, it might be a good idea to drop the pan and pull the mains off one at a time, replacing the one you took off before pulling another. If you do this, wipe the half of the bearing off and snap a couple pics of each one so we can take a look for you as well. Also get a picture of the crank journal while the main is off. Unfortunately I have seen a couple buddies motors go right out of the machine shop. One his crank looked like a ruffles potato chip as the mains were way to tight and the other, the pistons were too tight in the bore. None of which was noticed until after fire up and less than 50 miles. I hope this is not the issue for you.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
07-29-2010, 06:47 PM | #9 |
Re: Need help asap
I have seen the wrong sized bearings used do the same thing. It does happen. But it should be caught long before the engine leaves the shop. It should be caught before the pistons are even installed. Most decent builders mic everything so it wouldnt happen in the first place. The torque wrench thing is a good idea.
07-29-2010, 07:27 PM | #10 |
Re: Need help asap
I got my torque wrench and the highest it went before the engine turned was 120 ft lbs.is this too tight or is it ok.I talked to the machinist today whoo worked on the heads and he said is ok for it to be tight since is a new motor
07-29-2010, 07:39 PM | #11 |
Chevy Lover Till The End.
Re: Need help asap
In my opinion 120lbs is way to tight with the plugs out. I'd be for pulling the motor & tearing it down. Did your machinst line bore it, recon rods or new? It sounds to me like you either have a bad rod or the wrong bearings etc....
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
07-29-2010, 07:54 PM | #12 |
Re: Need help asap
Without plugs rotating resistance shouldnt be anywhere near 120ft lbs. Does it stay that hard all the way through rotation or does it turn easier in some places.
07-29-2010, 08:02 PM | #13 |
Re: Need help asap
It was 120 with the plugs in it haven't tried it without the plugs, the rods are new, and not sure if he line b ored it
07-29-2010, 08:11 PM | #14 |
Re: Need help asap
Pull the plugs and turn it over.
07-29-2010, 08:43 PM | #15 |
Re: Need help asap
07-29-2010, 08:58 PM | #16 |
Re: Need help asap
I'm sure mine is close or above that 120lb mark with the plugs in. But I have a good amoint of compression and Dynamic compression as well.
Definately need the plugs out with the TQ wrench.
07-29-2010, 09:56 PM | #17 |
Re: Need help asap
this motor is suppose to have to some good compression too.the block is bored .030 over with dome top pistons but I'll check it tomorrow without the plugs.wat should the reading be without the plugs?
07-30-2010, 12:42 AM | #18 |
ShortBus KingPin
Re: Need help asap
i would say anything over 75lbs is too much force.
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) |
07-30-2010, 02:07 AM | #19 |
Re: Need help asap
Even 75lbs seems tight. When I'm home I'll check mine with a TQ wrench. But I can spin it with the plugs out with a 3/8 drive ratchet which might be 10" long fairly easily.
07-30-2010, 12:16 PM | #20 |
ShortBus KingPin
Re: Need help asap
I agree totally. I think his engine is locking up. I would be interested in which machine shop did the build. I know just about everybody who is machining and pretending to machine in the town....
07-30-2010, 07:19 PM | #21 |
Re: Need help asap
the short block was done at a machine shop here in pasadena called jp's and the heads were done by craig caulk.
07-30-2010, 07:43 PM | #22 |
ShortBus KingPin
Re: Need help asap
Craig Caulk does good work. Never heard of JP's. From what your describing, I would say you have main bearing and/or ring and piston clearance issue's.
07-30-2010, 08:15 PM | #23 |
Re: Need help asap
Well guys I have bad news. Today after work I came home and took all the sparkplugs out of the motor and went to turn the crank over with the torque wrench and it was almost impossible to turn it over. So now I know for sure there's somethin wrong and as much as I hate to do this looks like ima have to pull the motor out and take it apart.
07-30-2010, 10:50 PM | #24 | |
ShortBus KingPin
Re: Need help asap
07-30-2010, 11:42 PM | #25 |
Re: Need help asap
The worst part about this is that this machine shop is not open anymore.this really sucks looks like ima have to take it apart and look for any signs.any ideas wat could cause this?
