07-28-2010, 10:10 PM | #1 |
700r4 torque converter lockup
I'm using a 86 GMC as a donor vehicle for the 305 and overdrive trans 700r4. I have been told the vacumn/electrical switch for the converter lockup is located on the firewall of the truck. Well, there are several things on the firewall with vacumn lines and wires, and I don't know which one is it. Obviously, i want to move it when the motor and trans come out, so i want to be sure i have the proper item. Does anyone have a picture of the switch?
07-29-2010, 10:32 AM | #2 |
Re: 700r4 torque converter lockup
in my opinion dont waist your time, I did the lock up deal on mine, and at 75 I flip the switch and it only drops it about 100 rpm's, not worth it.
07-29-2010, 01:59 PM | #3 |
It's Better With Nitro
It might be easier to get a toggle TCC lock up switch harness conversion. That's what I usually do for the 700R4 conversions.
07-29-2010, 03:43 PM | #4 |
I agree with vin63. A manual switch would be friendlier than the vacuum switch. But you don't need an overpriced kit from one of the aftermarket vendors. Just use a toggle switch from a hardware or home supply store.
Definitely make sure you hook up the converter clutch one way or another, though. It isn't just the 100 rpm. The converter puts a lot of heat into the transmission oil when you let it slip continuously. Ray |
07-29-2010, 05:02 PM | #5 |
So, if i go with a simple switch all i need is 12 volts sent down to the solenoid inside the converter and it will lock up. I'd rather have the control over it anyway than the automatic lockup. Also, I'm wondering how would you kick it down other than the switch, or would that be the only way to disengage it.
07-29-2010, 06:44 PM | #6 | |
Senior Car Nut
Larry Last edited by fleetsidelarry; 07-29-2010 at 06:49 PM. |
07-29-2010, 06:59 PM | #7 |
So Larry, my transmission will automatically shift out of OD back to 3rd when i hit the brakes even though the switch is still on?
07-29-2010, 08:12 PM | #8 | |
Senior Car Nut
I put a kit in mine, I believe it was from TCI, where one of the pressure switches is swapped out and a minor bit of rewiring done internally (pan off), I can't remember exactly, I'll have to look it up BUT I have subsequently read that you don't have to swap out the switch. I think Captainfab does just a simple switch arrangement. Someone talked about it recently on this forum. Here's one link I have about doing it yourself with a pressure switch and a vacuum switch: http://www.73-87.com/7387garage/drivetrain/lockup.htm here's one with a simple on-off switch: http://smokemup.com/tech/700r4.php
Larry Last edited by fleetsidelarry; 07-29-2010 at 08:34 PM. |
07-30-2010, 08:22 AM | #9 |
Senior Car Nut
I said: "I think Captainfab does just a simple switch arrangement." My bad, it was Txfirefighter whose diagram was referenced in a previous tread. The straight switch arrangement MAY lockup in 3rd also, and 2nd can apparently be done, also. I think if mine locked up in anything but 4th I'd want some sort of auto-disengage.
Larry Last edited by fleetsidelarry; 07-30-2010 at 08:34 AM. |
07-30-2010, 11:36 AM | #10 |
I used the adjustable B&M lockup kit, its around $180 works great.
http://www.streetperformance.com/m/c...-m-racing.html |
07-31-2010, 01:19 PM | #11 |
Not to hi jack this tread ,but can someone elaborate on whether it is actually necessary to hookup power to lock up converter.Or can it be ran with out any juice going to it as if not even being there i.e non lockup TH350.What I am getting at is I am going to install a TH350C which has a lock up converter but I am not going to hook power to converter yet.Can I run it with no issues as described?
07-31-2010, 04:31 PM | #12 |
Yes, you can certainly run the transmission without power connected to engage the converter clutch. The unanswered question would be about the long-term effect on the tranmission. You would be putting more heat into the transmission oil (from converter slippage) than the oil cooling system was designed to handle.
08-01-2010, 08:03 AM | #13 |
Thanks larry, think i'll go with the manual switch on the dash and retain control. I tow alot with my F250 diesel and it has that manual dash switch, only way to go while towing and i don't want lugging in the low to mid ranges when it's so much easier on the motor/trans to cruise in lower gear.
08-05-2010, 08:10 AM | #14 |
pulled the donor vehicle engine/trans together. everything intact along with carb and vacumn converter lockup switch. the tv cable, electrical plug not disturbed whatsoever. therefore i'm thinking all i will need to do is add 12volts off the key and plug in the vacumn line and the trans should totally function as it did in the donor vehicle including the converter lockup and unlocking. anyone disagree?
www.picturetrail.com/skysoldier173rd Last edited by skysoldier173rd; 08-05-2010 at 08:12 AM. |
08-05-2010, 10:31 AM | #15 | |
Ray |
08-05-2010, 02:23 PM | #16 |
someone on here said that when it downshifts to 3rd, it will automatically unlock the converter. Is that true? If so, don't need to do that. I did notice another double set of wires coming off the tranny wires harness hanging lose. wonder if that is the brake wires
If i do need to do this to the brakelights, does anyone know which wire would to the brakelights? |
08-05-2010, 03:32 PM | #17 |
08-05-2010, 04:27 PM | #18 | |
If you don't like it this way, you can wire the transmission to lock in 4th gear only, provided it has a 4th gear switch installed. Now you get to take off the pan, because you have to see what is hooked up on the inside of the 4 prong connector. There is no way to tell from the outside, because the switch will be open except when the transmission is in 4th gear. There is one other possibility you can check out that might save having to pull the pan. Look at the end of the harness that has the transmission connector. How many wires are there at that end? The number of wires, not the number of contacts. Ray Last edited by raycow; 08-05-2010 at 04:57 PM. |
08-05-2010, 06:09 PM | #19 |
sounds like the switch is the best option. just need to figure which wire goes to the converter solenoid. I'll look through some old threads here unless someone out there can help. I have isolated the switch now, so just need to know which wire to install the switch.
08-05-2010, 07:57 PM | #20 | |
Ray Last edited by raycow; 08-05-2010 at 08:01 PM. |
08-05-2010, 08:14 PM | #21 |
there are 3 wires, white,green and blue. I was refering to the vacumn switch on the other end of the wires that operates the converter solenoid. wouldn't you basically replace that with a toggle switch?
08-05-2010, 08:34 PM | #22 | |
You can check out the wiring before you install the transmission in the car. When you get it right, you will be able to hear the solenoid click. Ray Last edited by raycow; 08-05-2010 at 08:36 PM. |
08-05-2010, 08:48 PM | #23 |
sounds like that's what I really need. Probably should fuse the hot wire with an in line maybe? I'll search this forum and see if i can find some diagrams for wiring the switch and also the ground. Thanks for your help.
www.picturetrail.com/skysoldier173rd Last edited by skysoldier173rd; 08-05-2010 at 08:52 PM. |
08-06-2010, 11:32 AM | #24 |
Good news, for a change. I was looking at this diagram on a totally unrelated thread, and it just happens to show the internal wiring for the transmission connector.
http://chevythunder.com/16136965_ecm_diagram.htm According the diagram, the TCC solenoid is connected across A & D with A being the (+) side (the solenoid IS polarity sensitive), so connect power to A and ground to D. The 4th gear switch is connected across B and an internal ground, so if you want the converter to lock in 4th gear only, just put a jumper across B & D and don't use a ground wire. Disregard the wiring that goes to the ECM, because it doesn't apply in your situation. Ray |
08-06-2010, 03:32 PM | #25 |
Best news I've heard lately. Something about this build needs to be easy. This was supposed to be an easy bolt in, but it's fought all the way. Put a 413 in a 41 coupe once, don't think it was any harder than this.
Thanks Again |
