Old 07-28-2010, 10:30 PM   #1
Mike Bradbury
Mike Bradbury's Avatar
4/6 static question
I am in the middle of dropping and converting my C20 to a C10. I custom fabricated all the brackets on a Lincoln 9" rear to mate up to the custom trailing arms that I am also in the middle of building.
My question is what is the distance from the bottom of the frame rail to the top of the axle? I can fab a frame notch if I need to but I have heard that I might not need one. True? Knowing the distance from frame to axle will help me map out the placement of the coil over shocks and pan hard bar.
So anyone who has a 4/6 drop a quick measurement is all I need.
Mike
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 07-28-2010, 10:54 PM   #2
OARNGESI
OARNGESI's Avatar
Re: 4/6 static question
You should have about 3 inches i have 6 inch springs and 2 in lowering blocks with another inch and a half before it hits but i also have a stepside with no wood yet
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 07-28-2010, 10:58 PM   #3
Mike Bradbury
Cool thanks, These are custom trailing arms and will not need any lowering blocks.
Yeah I took the bed off already so I had a hard time mapping it w/o a load on it.
Mike
Old 07-29-2010, 02:17 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Mike, IIRC I had 2" between the top of my axle to the frame and 4" from the top of the pumpkin to the bottom of the bed.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
