Old 07-28-2010, 10:32 PM   #1
SRVBLUES64
Help
I finally found a 66 cab for my project truck however it happens to have a large hump instead of the small hump, I got it for 200 bucks!, my question is this, I do not have motor or trans for this truck yet, so I could do anything I wanted correct? what would you all think is best and the simplest to do. Will have to change the rearend if I went big block? will a 350 look stupid in there with a big hump? Pls send me your suggesstion and maybe the best place to get an engine thanks Jeff in Indy
SRVBLUES64 is offline   Reply With Quote
Old 07-29-2010, 06:44 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Help
Get yourself a small hump that bolts in from an older truck, as far as the big block versus small block looking silly, you can't see the hump from the engine compartment.
Old 08-01-2010, 12:37 PM   #3
raycow
Re: Help
Keep the high hump. You will appreciate the extra clearance when you are working under there.
Ray
raycow is offline   Reply With Quote
