Old 07-29-2010, 09:47 AM   #1
TCLARK
Sloppy seconds in Tennessee !
What's the best way to take the slop out of the steering of a '72 with manual steering? A new steering box? I put a new ( rebuilt ) one on a few years ago, it still had slop in it, rag joint & tie rods were in pretty good shape!
Where can I find a good box ?
Thanx !
TCLARK is offline   Reply With Quote
Old 07-29-2010, 10:35 AM   #2
68Stepbed
68Stepbed's Avatar
Re: Sloppy seconds in Tennessee !
You might want to check all your ball joints, tie rods, idler and pittman arms. A sway bar might tighten things up as well.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-29-2010, 10:59 AM   #3
litebulblsc
litebulblsc's Avatar
If the slop is in the box, I believe you can adjust it to take it out.
litebulblsc is offline   Reply With Quote
Old 07-29-2010, 11:08 AM   #4
rusty baker
'70 C-10 Primer
rusty baker's Avatar
You can loosen the lock nut and tighten the screw on the top of the sterring box to take out some of the slack. I was told it wasn't good for the box, but I did mine 10 years ago and it still works fine. I just wouldn't tighten it too tight.
"The difference between stupidity and genius
is that genius has its limits." Albert Einstein
rusty baker is offline   Reply With Quote
Old 07-29-2010, 11:12 AM   #5
litebulblsc
How would it not be good for the box? It is there for a reason...
Old 07-29-2010, 11:54 AM   #6
68Stepbed
68Stepbed's Avatar
It's not good for them because the gears develop a wear pattern. When you adjust them, they have to get new wear paterns, but sometimes get they out of sync.
Matt
Old 07-29-2010, 12:25 PM   #7
tqlspec
tqlspec's Avatar
You can install a steering stabilizer. Works pretty good. Basically it's a shock absorber system for steering components.
tqlspec is offline   Reply With Quote
Old 07-29-2010, 12:27 PM   #8
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Given the title of this thread.....I could sure have fun with that comment.
prostreetC-10 is offline   Reply With Quote
Old 07-29-2010, 12:35 PM   #9
rusty baker
'70 C-10 Primer
If you get them too tight they can bind suddenly and you can't steer. That would probably not be a good thing.
Old 07-29-2010, 12:37 PM   #10
70STOVEBOLT
70STOVEBOLT's Avatar
LOL, prostreetC10 I wish that were true!!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 07-29-2010, 12:58 PM   #11
Shane
Shane's Avatar
sorry, but that's incorrect.
the screw in & lock nut on the top of the steering box is there in order to adjust out the backlash (on initial set up) that is inherit to any gear-to-gear interface.
it has absolutely NOTHING to do with adjusting "slop" ... slop is the result of worn components.
Shane is offline   Reply With Quote
Old 07-29-2010, 01:18 PM   #12
rusty baker
'70 C-10 Primer
Whatever it does, when I tightened mine, it took play out of the wheel.
Old 07-29-2010, 01:22 PM   #13
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
you need to find the worn components in your steering and/or suspension. Worn parts cause slop, new parts fix it.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 07-29-2010, 01:31 PM   #14
TCLARK
Originally Posted by prostreetc-10 View Post
given the title of this thread.....i could sure have fun with that comment.
yeah............ I thought that would get attention ! ! I guess it was a crappy rebuilt gearbox from auto zone !
Old 07-29-2010, 01:32 PM   #15
70STOVEBOLT
My truck had a lot of slop, and replacing the ball joints, tie rods, idler arm, and pittman arm made a huge difference. Of course it has 195,000 miles on it so the gearbox has quite a bit of wear so there is still a little slop. But I agree, slop is caused by worn components.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 07-29-2010, 01:38 PM   #16
TCLARK
Mine is 95% Gearbox !
Old 07-29-2010, 03:15 PM   #17
Shane
Shane's Avatar
i love it when folks ask for advice and then get defensive when it isn't the advice they wanted to hear
Old 07-29-2010, 04:07 PM   #18
vectorit
What?
vectorit's Avatar
All these people that crank down on the internals of a worn out gear box, are just pulling the pin on a time bomb.
If the gear box is sloppy, be safe for yourself and others on the road with you and buy a replacement.
I am running a manual steering gear in my burb, and have been through a few replacements. My experience has been that, at their best there is some play. I personally have not experienced a manual gear, that feels as snug as a PS set up at the wheel.
Most of the vendors sell those replacements.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-29-2010, 04:22 PM   #19
TCLARK
Did I miss something ? I said I think the slop is mostly in the gearbox ( tie rods & rag joint are in good shape ) & where to get a good one.
Old 07-29-2010, 05:49 PM   #20
68Stepbed
68Stepbed's Avatar
OK you keep saying your tie rods and rag joint are good, but what about everything else? Hows your ball joints? What about the idler and pittman arms? What about the spindle bearings? Are they in good shape and greased well?
There are so many factors that come into play with steering "slop" or "play". If you changed the gear box and still have the same symptoms, it may be something else. Gear boxes, especially manual gearboxes, really take ALOT of abuse and a VERY long time to actually wear them out. I really don't think it's the problem.
Matt
Old 07-30-2010, 09:47 AM   #21
prostreetC-10
My Carbon Footprint
Just lightly throwing this out there........
how are you checking your parts for wear? It is easy to incorrectly check parts. I'm assuming your truck is in the air? If you have just 5% wear in each area....5%+5%+5%+5%+ a lot of wear. For me it always seems to be the darn idler that creates the most wear.
