engine swap ideas????
so currently i'm running an over cammed 350, thats bolted to a built 700r4 with a posi and 3:73 axle ratio. but its not a good driver, it spits slobbers and burps all at the same time. But when you let it loose it roasts the tires into drive,
I have an 04 5.3 and a 94 lt1 already along with factory wire harness and parts vehicles, but was wondering on peoples opinions I know that I can build a roller cam carbed small block that will run great and have tons of tourque, reuse my exhaust, trans, and acc. My question is what should I do, I've been reading on 5.3 swaps, and lt1 swaps, but haven't found an actual total cost for doing this. Has any one every counted up the total build cost? ( I know its something no one usually does lol OUCH!!!!!) This is a buget build too, don't get me wrong I would love to drop a $1000 bucks on shiny serpentine pulleys and mounts, but it ain't gonna happen, its not a show truck, its just something to putt around in, and roast the tires off every once and a while... |
#2 | |
Re: engine swap ideas????
Why not put a decent cam into your 350 and be done with it? |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
You would be out mounting hardware, exhaust ( headers), about $600 for the carb conversion, etc, etc.
If it were me, I would build it with the FI, get the tune, trans adapter, DIY the harness, headers/manifold, and drive the crap out of it, I think you will be surprised with the power that 5.3 will have with a good tune, then you could do a cam and such later. Your mileage for your putter will be great!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 07-29-2010 at 05:45 PM. |
| Bookmarks |
