Old 07-29-2010, 04:42 PM   #1
zac
zac's Avatar
'70 K10 throwout bearing
Pulled everything apart to replace a very noisy throwout bearing, got a new one from Autozone (Timken 614018). When I got home and looked at the new one, I noticed it had a little pin going across the groove where the release fork rides. It would in theory keep that portion of the assembly from spinning, I guess, becase the pin would hit the fork. My old bearing doesn't have the pin. What's the deal?
zac is offline   Reply With Quote
Old 07-29-2010, 04:51 PM   #2
vectorit
What?
vectorit's Avatar
Re: '70 K10 throwout bearing
I don't know what the deal is, but on mine it didn't have the pin you describe as well.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-29-2010, 05:03 PM   #3
zac
zac's Avatar
I found the bearing from my '72 parts truck with surprising ease. It seems good, so I'm going to go against my better judgement and repack it and run it. It should last as least as long as it takes me to wear out my already kind of tired engine. I'll have it all apart again soon enough..
Old 07-29-2010, 06:18 PM   #4
68 TT
Still plays with trucks
68 TT's Avatar
The throw out bearing I got had an oblong shape to the center area to achieve the same purpose as the pin you have on your new part. Maybe it is a design improvement.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-29-2010, 06:35 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
the slot is something about holding it on, My old one didnt have a slot I put the slooted one on today
No diff. I believe. (just did this like 20 min. ago)
John
1999 Toyota Tacoma 4x4
