Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 07-29-2010, 08:35 PM   #1
bigwheel15
bigwheel15's Avatar
Small welder for body work?
Shortly after buying my 81 longbed and really going over it I realized a welder is going to be something im going to have to buy. I came across a lincoln weldpack hd flux core welder for $140. Now my question is, would this be any good for small projects such as shaving handles, stake holes, welding in patch panels and the such?
http://www.homedepot.com/webapp/wcs/...m#BVRRWidgetID
bigwheel15 is offline   Reply With Quote
Old 07-29-2010, 10:44 PM   #2
crushermechanic
crushermechanic's Avatar
Re: Small welder for body work?
no you dont want that type of welder for body work. you want a welder that has gas set up. flux core wire makes a nasty weld and is not good for sheet metal. i would look at the new miller autoset welders they are killer.
crushermechanic is offline   Reply With Quote
Old 07-30-2010, 12:12 AM   #3
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
+1 on the nasty welds from a flux core wire. You'll also need to look for something with continuous control on voltage and wire speed. If it has discrete notches as you go from 0-10, keep looking.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 08-02-2010, 05:11 PM   #4
gixxerpymp
http://www.sears.com/shc/s/p_10153_1...&blockType=G27
Try that. I've heard great things about it. I'm actually on hold right now waiting to order it.
gixxerpymp is offline   Reply With Quote
Old 09-20-2010, 12:17 PM   #5
pockets
pockets's Avatar
I too have been looking at the Lincoln from Sears. Anybody else have thoughts on it?
Project Bad Karma
pockets is offline   Reply With Quote
Old 09-20-2010, 01:05 PM   #6
ERASER5
ERASER5's Avatar
Most of the Lincolns at Lows, Sears, ect are tapped controls. You know, the knob "clicks" as you turn it. Only the Lincoln POWER MIG has the continuous control. The know turns smoothly from min to max.
Just some FYI.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-20-2010, 05:44 PM   #7
Schralper
Schralper's Avatar
yeah if ya want crappy welds. 110V sucks!
+ 24ga - .125" weld capacity? guess you never plan on welding anything other than sheetmetal huh?
I've got a miller dvi mig & tried 110V just not as good as 240.
if you want good looking welds, less grinding, etc., you're gonna wanna use Ar/Co2 mix & .023 wire. flux core if you want ratrod crappy welds.
Figure out how much $ ya got an buy the best you can afford.
Check craigslist?
Schralper is offline   Reply With Quote
Old 09-20-2010, 05:54 PM   #8
pockets
pockets's Avatar
in my case I do not have 220v, nor can I put one in.
Project Bad Karma
Old 09-20-2010, 06:34 PM   #9
LONGHAIR
110volt migs are fine for sheet metal work. They are far more convenient/compact and you don't need all of that power for thin gauge stuff.
The main thing to draw from this is that you really do want gas and thin wire.
Flux core has it's place, but body work is not it.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-20-2010, 07:34 PM   #10
pockets
pockets's Avatar
I can't speak for bigwheel15, but I plan on bodywork and the occasional bracket or drop member
Project Bad Karma
Old 09-20-2010, 11:35 PM   #11
andyh1956
see if you can find a miller cricket. they don't make them anymore, but it will do everything you want right now. it runs on 110v & uses .023" wire. mine is handier than a shirt pocket, i use it ten times more than my miller 210. i load it up & take it with me all over. it will even run off a portable generator. good luck!
andy
andyh1956 is offline   Reply With Quote
