07-29-2010, 10:06 PM | #1 |
Brake Booster
I want to mount my Brake booster on the firewall of my truck. What do you guys think?
07-30-2010, 12:29 AM | #2 |
Re: Brake Booster
I was thinking about doing this too but at the same time having it hidden away would help keep the firewall clean and would look nice
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
07-30-2010, 03:24 AM | #3 |
Re: Brake Booster
Compromise. Keep the booster and master cylinder on the frame and run a remote reservoir on the firewall for ease of servicing.
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon |
07-30-2010, 07:09 AM | #4 |
Re: Brake Booster
I guess it's just depends on your preference, but I'm keeping mine under the floor to keep the firewall less cluttered. The remote reservoir sounds like a good compromise though.
Last edited by Russell Ashley; 07-30-2010 at 07:12 AM. Reason: correct misspelled word. |
07-30-2010, 08:43 AM | #5 |
Re: Brake Booster
If I were going for a show truck I would have done the under floor for a clean firewall. (This goes for the battery tray, too.) I just want a really nice driver so I opted for functionality. By keeping the booster and battery on the firewall it will be easier to service. I won't have to crawl under or pull up carpet to check fluid level or see the battery terminals are corroded, or jump start, etc. Decide what you want for your truck and what works for you.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
07-30-2010, 08:50 AM | #6 |
Re: Brake Booster
i was looking at something like this to keep he firewall clean but there is not http://www.kugelkomponents.com/produ...akesystem.html
edit: I guess looking there is an option for a booster now i wonder if it will fit http://www.kugelkomponents.com/produ...kesystem1.html
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin Last edited by jimig1; 07-30-2010 at 08:59 AM. |
07-30-2010, 11:59 AM | #7 |
Re: Brake Booster
At No Limit we have both types. Firwall mount kits with 7' Dual diaphram boosters, or 8" dual. Two styles of chassis mounts avail, one kit to re-use the stock pedal, and a kit that comes with a new pedal. Chassis mount kits can use 7" or 8" boosters, or hydroboost units. check them out at www.nolimit.net
07-30-2010, 12:18 PM | #8 |
Re: Brake Booster
Have any of you guys used a camaro brake pedal/master cylinder/booster? I have a rebuilt '79 camaro brake pedal/master cylinder/booster. i got it out of the camaro that I got my sub frame out of. I understand that it is neccessary to remove the e brake handle to do this. I have also read that you can use a 73-87 e-brake pedal and that it will bolt right up to the back side of the hood hinge. Any one try this?
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
07-30-2010, 07:24 PM | #9 |
'59 pache
Re: Brake Booster
I used a '95 S-10 booster on mine.
07-30-2010, 11:53 PM | #10 |
Re: Brake Booster
I did the Kugel unit on the 52 that I am doing. Looks great so far but I still don't have everything done yet to see if it works. This truck is killing me and taking way to much time...lol. http://67-72chevytrucks.com/vboard/s...=206021&page=6 Thread 137 for some pictures.
Bernie |
07-31-2010, 11:29 AM | #11 |
Re: Brake Booster
AHHHHH..... so after looking at a few pics of them mounted on the firewall I decided to put it on the frame. I thought it would look nice but I guess not I guess the engine conparment is just too small for it.
Does anyone know if the Brothers pre-bent lines will connect to a ford 8.8 rearend with discs |
08-06-2010, 01:03 AM | #12 |
Re: Brake Booster
Looking for a frame mounted MC and booster. What brand are you guys running I have front and rear disc brakes
08-06-2010, 08:12 PM | #13 |
Re: Brake Booster
I got the adapter bracket, master, booster, proportioning valve, and residual valves from No Limit. Still in the install process though. I'm 4 wheel disc too.
08-07-2010, 12:15 AM | #14 |
Re: Brake Booster
I'm running a hydroboost out of an 05 chevy truck. I bent all my own brake lines. It isn't that bad if you take your time.
Kim |
08-07-2010, 01:17 AM | #15 |
Re: Brake Booster
I used the stock pedel, fabbed my own bracket and used an 8" hot rod type booster with 74 truck MC and proportioning valve. Note that I found from experience that bleeding the brakes with the expansion coils vertical is almost impossible because of air pockets, in the final install they are horizontal.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 08-07-2010 at 01:30 AM. |
08-07-2010, 12:26 PM | #16 |
Re: Brake Booster
Orrie, this set up will work fine, but you may want to extend the lower pedal. The stock ratio is appx. 8.5 - 1. this is good for a manual brake, but will feel too soft with the booster. By extending the the linkage rod mount hole down about an inch, you will change the ratio to appx. 5.5 - 1. You can fab up a bolt on link to do this. (we have them, $12) This will give you a lot more pedal feel, and reduce the amount of pedal travel needed. Many times, I cut 2" off of the upper pedal, just below the pedal head, and weld it back together, it makes driving much more comfortable.
08-07-2010, 03:18 PM | #17 |
Re: Brake Booster
Rob - thanks for the insight. If you look closely you will see that I had a manual MC mounted before, drove it for almost 15 years daily with no problems and developed very good left leg muscles. That is an early photo, I have had it all set up with the cab set and it seemed to work ok as is, mc works fine before pedel gets close to the floor. I haven't tried it with the engine running. I think I'll change the ratio like you said, easy to do with it still open. I'll wait on the other and see if it bothers me with the new seats and column. I really appreciate you pointing out that ratio, with the power booster I will not need as much leverage. I assume I will have to look at the horizontal arm adjustment for pedal postion?
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 08-07-2010 at 03:21 PM. |
08-08-2010, 03:36 PM | #18 |
Re: Brake Booster
You can, but your best bet is to adjust the linkage to set the lower pedal arm right up to the toeboard (keep the return spring and rubber bump pad), then, when it's all bled and tested, shorten the upper padel arm to set the pad to your liking. keep driving!!!!
08-10-2010, 08:32 PM | #19 |
Re: Brake Booster
Who sells frame mounted MC brake booster kits? Who has used the kit from Brothers trucks. What about their brake lines do they hook easily?
08-10-2010, 09:26 PM | #20 | |
Re: Brake Booster
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
08-10-2010, 11:23 PM | #21 |
Re: Brake Booster
The originals are stamped steel, not cast.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
08-10-2010, 11:33 PM | #22 |
Re: Brake Booster
Good to know....I was not sure, will make for easier welding being stamped steel.
11-07-2010, 02:06 AM | #23 |
Re: Brake Booster
11-07-2010, 08:53 AM | #24 |
Re: Brake Booster
I bought mine at Tucker's but the kit came from CPP. It fit good and was easy to install with the cab on. I used the style that kept the stock pedal and arm. On my 57 the brake arm is cast steel. I used the NAPA multi-layer brake lines and made my own. Cheaper and not difficult at all.
11-07-2010, 09:24 AM | #25 |
Yellow truck club
Re: Brake Booster
Well you've got no limit which has been mentioned acouple fo times. CPP also has kits. Mikes bump and grind who is on this board has a kit which I used.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
