Old 07-30-2010, 12:21 AM   #1
CenValyCali
Build thread / Advice
I got my 63 today and I've got to say maybe it was a bad trade I traded my square body for it that ran good, smogged everytime and had A/C! Anyways the square bodies gone and now I have A 63. It's got a 62 style grill with the 62 light bezels. The fenders got bondo, the doors and the bed. And it's not sanded down I took a look under the bed and it looks like there's about two 2x4 in each corner supporting the bed, So 4 corners with 2 2x4. Then I look at the rear end and it's held on with 2 leaf springs. I didn't know these trucks came with leafs? I'm guessing there not suppose to be there, but that's not what scares me. It's the fact that theres only two on each side . Also owner that had the truck before me put in two fuel tank and decided to cap off the tank behind the seat. Now I'm not sure this truck came with the tank behind the seat but everthing I've seen said it's suppose to have it. Well now the good The motor is out of a 1987 Camaro and so is the rear end. The motor is carburated and runs very well. I've got power steering but my brakes need a little adjusting. I ran through a stop sign tonight. The exhaust is all brand new from the headers back to the flowmasters. Even the pipe is new. Interior is ok. The guage cluster doesn't really work but that could be from not being hooked up. also the linkage on my shifter is backwards Forgot to mention the tranny is a 700r4. Well that it for now. I would like some help with maybe finding a gauge insert and maybe finding after market guages. Also am wondering about the leafs and the bed being on 2x4. Thanks a head of time. I'll post pictures when I get my camara back. O yeah did these trucks come with five lug? It's a five lug. I guess that how I can tell if my rear end is really out of a camaro or not. It should have the small five bolt pattern. Thanks
Adam
CenValyCali is offline   Reply With Quote
Old 07-30-2010, 07:30 AM   #2
skoffice
skoffice's Avatar
Re: Build thread / Advice
As far as I know, if your truck is a GMC it should be leafs, because I think only the GMCs came with leafs. I have heard of Chevys that had been custom ordered from the factory with leafs too though. If the brackets are riveted on then they are original. I think they only came 6 lug, so someone must have updated the front end as well. Are they disc up front? If so then thats most definitely the case. The lug patterns should be different though, 5x5 up front and 5x4.75 out back.
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 07-30-2010, 02:38 PM   #3
onequickchevy
onequickchevy's Avatar
Sounds like you got rooked, and for punishment you should send it to me, but only if the doors are good!! Just kidding. Sounds like a good start, just needs some finishing up. Show us some pics as soon as you can. Also, the 2x4 boards are there to do the job the bed floor used to do if I am reading you correctly, they are just using the boards as a spacers.
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 07-30-2010, 03:58 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
ooook...lot of info to digest in this post. From what I gather
1. yes leafs are normal, I think its only the 4,5,6 trucks that had trailing arms normally.
2. are ANY of your gauges working? If just the speedo is inop, that may be because the 700r4 uses a different style cable, and an adapter can be purchased.
3. The trucks were 6-lug, the rear end may be out of that same Camaro (since you mentioned it for the motor), and the front may be the 73+ style truck suspension, hard to tell without pics.
4. remove the in-cab tank, no reason to have it in there if it isn't doing anything
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-30-2010, 07:08 PM   #5
CenValyCali
OK sorry guys the truck is a 62 not a 63. It's also a chevy not gmc. Looks like the lug is a wide 5 lug like most chevy truck. I'm not understanding this at all. The guy who sold it to me said it had a 1987 camaro rear end and a motor. I though all camaro's had small 5 lug? Anyways no big deal. Also no disc brakes. Stay with me
Old 07-30-2010, 07:12 PM   #6
CenValyCali
For punishment I'll sell it to you for 3000.00 . The body on this thing is jacked up but can be fixed with some metal work and filler. The bed has the floors in it still but will probably come out eventually to post new boards. The 2x4 are definitely used for spacers but they can't be same. Is this original? What happens when the wood expands? Easy fix with square tubing(metal)? Also shouldn't the bed lay on the frame or close to it? Thanks
and stay with me .
Old 07-30-2010, 07:16 PM   #7
CenValyCali
1. Thanks, I can sleep better knowing they are original. The other leafs are laying in the back of my bed so there going to go on eventually.
2. None of the gauges work. I have a after market temp gauge and a after market pressure gauge. they both work but are not displayed in the gauge cluster. Do you have a link to the adapter? Thanks
3. I'm going to have to get some pics. What should I take pictures of so that it will be easy to identify?
4. It's already out. Thanks, stay with me
Old 07-30-2010, 09:18 PM   #8
Bugeyev8
Bugeyev8's Avatar
All Chevy trucks 60-66 had trailing arm suspension, GMC had the leafs in 60-61 only as I recall
Bugeyev8 is offline   Reply With Quote
Old 07-31-2010, 06:42 AM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 07-31-2010, 07:36 AM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
other way around...60-62 gmc were coil, 63-66 gmc were leaf.
Old 07-31-2010, 08:23 AM   #11
lakeroadster
x2
Post up some pictures!
lakeroadster is offline   Reply With Quote
Old 07-31-2010, 11:15 PM   #12
CenValyCali
Pics will arrive shortly . Took a look at the brakes today and there disc. Also went to the junk yard and got a brake reservoir for ten bucks. Took it off a 90's chevy. It fit's much better and will also hold more fluid. Bleed the brakes and now I've got some breaks. Still kind of wondering why i'm overheating at stop lights? It's got a electric fan and I've never used one before but I imagine they have to work good. Should I just go to mechanical and maybe run the electric for supplement? Anyways thanks. I should have pictures in a few minutes.
Old 08-01-2010, 12:09 AM   #13
CenValyCali
OK here's some pictures ....
First some of the body needs work.
Now here's a few of the wood that's holding the bed off the frame... You can also see the hangers? Leafs original or possibly a different frame?
Here's a few of the rear end and you can see the leafs and shocks.
Inside bed... Looks like the rest of the leafs...
Inside cab...
Motor...
Wide 5 lug...
WHAT IS EVERYONE THINKING?
Old 08-01-2010, 12:11 AM   #14
CenValyCali
Wow now that I look at that frame it looks like my square body frame. The hangers look similar.
Old 08-01-2010, 01:37 AM   #15
Captainfab
60-66 Nut
That's what I was going to say.....looks like a '73-'87 frame, including the saddle tanks. Looks to me like the PO just removed most of the springs from the original springs.
No offense intended, but that PO did some scarry looking work on that truck. I myself wouldn't drive it until some things were fixed.
Old 08-01-2010, 01:52 AM   #16
Bugeyev8
Bugeyev8's Avatar
looks like a stock rea end too not a Camaro one, the frame and shock placment leads me to believe that it is indeed a 73 or later truck, I would fab up some metal mounts for that bed asap! otherwise the truck looks like a good start, body looks good enough, what are your plans for it ?
Old 08-01-2010, 01:58 AM   #17
Captainfab
60-66 Nut
No that isn't a stock C10 rear end. It does look like the whimpy 7.5/7.625 10 bolt from a 3rd Gen F-body to me.
Old 08-01-2010, 02:25 AM   #18
CenValyCali
No doubt it will take me a long time to fix what the last owner tore up. There's not really any close up's of the body work but let me tell you, the amount of filler that this guy used could of lasted a few trucks Just from the pictures can you give me some pointers on where and what to fix? Thanks
Old 08-01-2010, 02:31 AM   #19
CenValyCali
Thanks for the post, I'm going to come up with something to lift the bed off the frame. It looks like the 2x4 made the body line perfect but it can't be safe
Plans are to lower it even, add skinny white walls with artillery wheels. Body work. Maybe metal flake the roof. Not in that order. Everything is already up graded as far as the drive train goes. Power steering is great. Motor is very strong.
Old 08-01-2010, 02:33 AM   #20
CenValyCali
Does the whimpy 3rd generation Camaro's come with the chevy big 5 lug rear ends?
Old 08-01-2010, 05:26 AM   #21
jonzcustomshop
1961 crewcab
no but a cop car caprice, or chev/buick /pontiac wagon will 77-90?
Old 08-01-2010, 01:04 PM   #22
CenValyCali
I'm wondering if the guy would go through all the trouble of putting one in when there was probably a truck rear end in it. For sure this is not a square body rear end?
Old 08-01-2010, 02:27 PM   #23
TheDark1
Intentionally Left Blank
TheDark1's Avatar
How's the cab mounted? If it's a square body frame, the cab mounts would be modified (not riveted). It looks like you're going to need to get some numbers off of each major component to identify their origins. Axles can be redrilled/replaced with different patterns, so take too much for granted. --Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 08-01-2010, 02:53 PM   #24
raycow
I'm thinking an Astrovan could have a 7.5" rear with a 5 on 5" bolt pattern. Any takers?
Ray
raycow is offline   Reply With Quote
Old 08-01-2010, 03:45 PM   #25
blackedoutharley
An Astrovan (or GMC Safari) would have the small 10 bolt rear with a 5x5" bolt circle. The frame does indeed look to be a later model.
blackedoutharley is offline   Reply With Quote
