Old 02-20-2003, 07:24 PM   #1
maritime_bowtie
2wd front end replacement
Hey,
I have an '87 c-10 2wd that i'm rebuilding. I already have the body complete, (new doors,fenders in & out,rockers and cab corners,box,tailgate...) and now i'm onto the front end. I have new upper and lower control arms,ball joints, inner & outer tierods, idler arm & pitman arm, but when i was looking at my cross member, it looks a little seedy. How big of a job is it to switch that out? Do I have to support the motor or what? I am stumped about how to go about this, but it has to be fixed, besides my annual vehicle inspection is due next month and i'm not sure if it will pass because of the "hole" in the front of it.Any insight will be greatly appreciated.
maritime_bowtie is offline   Reply With Quote
Old 02-21-2003, 12:11 AM   #2
CustomChevy
YES, motor has to be suspended, other than that it is a straight unbolt and bolt back in. Definitely clean as much as possible and use some Liquid Wrench to help loosen frozen bolts. With the steering linkage removed from spindles, and brake lines disconnected, you can unbolt the entire assembly. Have the engine mounts unbolted and the engine suuported. Place a jack under the crossmember to support it when the bolts are removed. When changed out, you gotta reconnect and bleed the brake system.
Since you already have the a-arms, brake parts, and steering parts removed, it should be pretty easy. Should only take you a few hours to finish the swap.
Good luck!!
CustomChevy is offline   Reply With Quote
Old 02-21-2003, 11:01 AM   #3
maritime_bowtie
Thanks alot Custom Chevy, I'll let you know how it turns out. It must be nice to live in a place with rust free vehicles.
'87 2wd c10
Daily driver
My project in progress...
(when money and time allow)
Old 02-22-2003, 05:54 PM   #4
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I have good front crossember if you are interested. I custom fabricated a crossmember for my 83 by moving in into the frame 2" for the ultimate low. The kit was bought from turner enterprise out of California. Let me know what you think.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 02-22-2003, 06:00 PM   #5
phantom dually
Here they are!!
Old 02-22-2003, 06:02 PM   #6
phantom dually
Heres the crossmember I put in.
Old 02-23-2003, 10:51 AM   #7
maritime_bowtie
Thanks, but actually I'm going to go pick up my new cross member later this week, its used, but it will clean up nicely, and besides that, can't beat the price. ($75cdn). Later, Maritime_bowtie
'87 2wd c10
Daily driver
Old 02-23-2003, 01:19 PM   #8
CustomChevy
phantom: that frame and suspension looks like it is coming along real nice. that rear bag setup looks pretty sturdy. keep on, keepin' on!
Old 02-23-2003, 08:52 PM   #9
1FaastC10
1FaastC10's Avatar
phantom, are you planning on fabricating motor mounts too? since you just notched the cross, rather than seectioning out the whole thing, your stock mounts wont work.
1FaastC10 is offline   Reply With Quote
Old 02-23-2003, 10:56 PM   #10
phantom dually
Yes I am using a fabricated mount made by Turner engineering in California. They ran about $75 shipped and simply bolt to the crossmember. You will then use the 70's style motor mounts which bolt to the motor rubber and all. Let me know and i can post a pic for you.
Old 02-23-2003, 10:59 PM   #11
phantom dually
Thanks for the props there CUSTOM CHEVY. I have been working on this for a while and never really planned on going this far. One thing lead to another and well you know the rest!!! I could hav been done by now and saved some money but i have changed plans in this process. I beleive now I am on track as I am not leaving anything undone on my quest!!!
