Old 07-30-2010, 11:32 AM   #1
De Fuego
De Fuego's Avatar
Sensitive steering. Need help
Has anyone ever had the issue of real sensitive steering. When I'm driving say 30 mph or faster, and I hit a rut or as we have here, miles of ruts, my truck will easily pull to one side. The dangerous part is that my steering is so "touchy" that when i try to correct it, it will sling shot me back to the other side. I've change the power steering box once and it stayed the same. Any suggestions? I have 18 in wheels, disc brakes up front and lowering springs.
De Fuego is offline   Reply With Quote
Old 07-30-2010, 11:42 AM   #2
LONGHAIR
Re: Sensitive steering. Need help
I would say that you have an alignment issue. Probably not enough caster in the first place and likely some toe-out to make it worse.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-30-2010, 03:27 PM   #3
chevyrestoguy
chevyrestoguy's Avatar
It sounds like your caster is way off. Little or no caster will exhibit symptoms very close to what you're seeing. I like a lot of caster because it makes the vehicle track down the road better and you're not constantly trying to bring it back on center all the time.
chevyrestoguy is offline   Reply With Quote
Old 07-30-2010, 03:31 PM   #4
De Fuego
De Fuego's Avatar
Hate to sound ignorant, but what exactly is Caster and how do i correct it?
Old 07-30-2010, 03:36 PM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
unless you have an alignment rack, you cannot correct it. You will have to take it and get your truck aligned by someone.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-01-2010, 05:38 PM   #6
chevyman8
chevyman8's Avatar
I agree that its alignment. Mine was fine before i cut the springs, now it follows the road everywhere and especially patch jobs. My problem is I now have negative camber (tires are pointing inward). Look at your tires and see if they're tilted in or see if the tread is worn down on the inside.
chevyman8 is offline   Reply With Quote
