Old 07-30-2010, 01:24 PM   #1
roofingbloke
Help Wanted
Hi all. I have just purchased a solinoid system for my ar ride setup, i am trying to find a wiring and plumbing diagram for this product, any help would be great,
ARP airridepro.com
Model:VSS 5338
Pressure; 1.5-1.8kf/cm2
Please see pictures.
roofingbloke is offline   Reply With Quote
Old 07-31-2010, 04:05 AM   #2
roofingbloke
Re: Help Wanted
Trying to find this company but computer directs me to firestone products ??
Old 07-31-2010, 08:38 AM   #3
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Re: Help Wanted
made by airbaggit.com, everyone here(me included) will tell you to stay as far away as possible!
I tried to find some info but they don't have any diagrams
Ghostwhite is offline   Reply With Quote
Old 07-31-2010, 10:35 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Help Wanted
I don't think that is from airbaggit.com AKA AIM/Chassis Tech. I believe that is a spool valve assembly that is used in industrial air applications. If so, they are not "bubble tight" and not suitable for automotive applications.
Where's Shane at? He's the expert on the industrial stuff.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-31-2010, 10:39 AM   #5
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Re: Help Wanted
It might not be but that is where I found it, Valve Block
Supposedly only good to 120 PSI but recommended for Competition Hopping
Old 07-31-2010, 10:42 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Help Wanted
Nope, you are right and I was wrong. At least those cheese balls sell it. I still think it's industrial valves.
Articles-
"Refining Sierra"
Old 07-31-2010, 10:45 AM   #7
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Re: Help Wanted
I think you are right with them being industrial, I searched through google a couple times with different names that popped up like MVS and another I can't remember. Airbagit is the only place I have seen them used in an auto application.
Old 07-31-2010, 11:06 AM   #8
Shane
Shane's Avatar
Re: Help Wanted
those are in all likelihood re-badged Chinese knock-offs of a SMC/Parker designed industrial spool-style valves ... probably not what you want to hear but they are notorious for failing due to "contaminated" air (dirt, oil, rust,etc ) and this type of environment is inherent in most automotive applications. Spool valve setups are best used in a filtered "clean air" environment that is most commonly found in industrial automation applications.
hope this helps ... good luck
Shane is offline   Reply With Quote
Old 07-31-2010, 01:18 PM   #9
roofingbloke
Re: Help Wanted
Yep found them on airbagit.com looks like i have bought a problem, the attached wiring diagram for air pipes is very poor, i think i will cut my losses and find another product, But which brand, I dont want to go up and down fast i just need the truck to sit low at shows etc.
Old 07-31-2010, 01:42 PM   #10
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Re: Help Wanted
Accuair for the win!!
Accuair VU4 Manifold is a top notch product if you want to stick with a manifold for easy wiring and plumbing Suicide doors Listing
There are others out there that I am not terribly familiar with that may be just as good.
If you want to use regular valves then you can't go wrong with Parker or SMC Suicide door Normal Valves
Suicide Doors is one of many good vendors, Check out the Vendor Section
Old 07-31-2010, 11:18 PM   #11
Shane
Shane's Avatar
Re: Help Wanted
SMC/Parker valves are very hard to beat for price, reliability and performance. If they ever become "stuck" they are very easy to disassemble, clean and reassemble. Replacement parts are readily available as well.
I prefer SMC 3/8" valves for their lift speed on the inflate side but prefer flow regulators & exhaust mufflers on the same 3/8" to slow it down on the dump side. Several folks here on the board use 1/4" for dumps with very good results. Keeps the truck for dropping to fast or too hard. I purchased my SMC's from suicide doors dot com.
Good Luck.
