07-30-2010, 01:59 PM | #1 |
Shop compressor
I plan on using 3/8' drive tools and my trusty angle grinder for most of what i do at home do you think this compressor will be able to handle it? 1/2' only when the 3/8" can't get it done...
4 HP, 29 Gallon, 120 PSI Compressor
This is were I try to sound clever and cool at the same time. |
07-30-2010, 02:44 PM | #2 |
Its a Truck Thing......
Re: Shop compressor
Should be, the grinder may put a load on it, but the rest should be ok.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
07-30-2010, 02:53 PM | #3 | |
Re: Shop compressor
You might want to think about running 3/4 line if your going to plum your shop with air fittings. Volume makes a big difference and I have a 5 HP 80 Gallon Compressor that sometimes has a hard time keeping up. I only spent $400 on the compressor and if I keep Painting I think I am going to step up to the plate next time and get the $1500 one that makes way less moisture and is way more efficient. Only makes sense to spend the money when your spraying $2500 in paint. Good luck with your Compressor. JRBECK64 |
07-30-2010, 02:56 PM | #4 |
Re: Shop compressor
The cubic feet per minute and pressure rating is the most important (usually rated CFM @ PSI). The other ratings are important but what really counts is the sustained flow. Most air tools run below 100 PSI. If you plan on ever wanting to run a large sander, sand blaster, cut off tool, tools that need a large volume of air at a higher pressure for long periods of time you need something that can do something like 12 CFM @ 90 PSI. Spend absolutely as much money as you can on the compressor. I have a 60 gallon sandborn that is suppose to be 11.5 CFM @ 90 PSI and I seriously doubt it's capable of that. I have problems with it keeping up with my 5" DA sander, or my 3" cut off tool. If I had the extra cash I'd sell the one I had and buy this.
http://www.tractorsupply.com/air-com...ressor-3301332
Blayne |
07-30-2010, 03:06 PM | #5 |
Family Man
Re: Shop compressor
I have this one, runs airtools good with minimal pressure regroup and runs a DA decent...just not long periods of time.
http://www.sears.com/shc/s/p_10153_1...6&blockType=G6 |
07-30-2010, 03:24 PM | #6 |
Re: Shop compressor
i think you'll find alot of limitations with a small compressor like that
07-30-2010, 04:20 PM | #7 |
Re: Shop compressor
Can you afford a compressor with more cfm's? I have a 10 cfm, 60 gallon compressor that is much too small for what I do (sandblasting, painting, etc). Buy the most cfm's you can afford.
07-30-2010, 04:34 PM | #8 |
Re: Shop compressor
Get a 2 stage compressor. If you run a single stage all the time you may burn it up.
07-30-2010, 06:17 PM | #9 |
vw guy & now c-10 guy
Re: Shop compressor
I agree. get a 2 stage. thats the only way the compressor will always have a continuous supply of air. I have a 6hp 80 gallon 2 stage porter cable that was only $1000 and it works really good- tools never slow down
07-30-2010, 08:03 PM | #10 |
Re: Shop compressor
Thanks fellas as usual i have been educated...
