07-30-2010, 08:57 PM | #1 |
Where does this go?
I am putting my interior back together and I cannot remember where this spring goes. I think it was somewhere in the heater/AC system. 1 3/8" long body x 1/2" diameter with two 3/4" long hooks facing each other. Was painted red. It is a fairly stiff spring. Thanks.
07-30-2010, 09:12 PM | #2 |
Re: Where does this go?
It's starting to come into focus in my weak mind - air vent door, passenger side, but what do the ends hook to? LMC catalog is a bit vague.
07-30-2010, 09:40 PM | #3 |
Could it be from the bottom bracket with hole on the vent door to a hole on the lower outer edge of the vacuum actuator bracket?
08-27-2010, 02:40 PM | #4 |
looks like it's off of your seat. does your seat slide forward and backward?
08-27-2010, 11:06 PM | #5 |
Desert Rat
Depending on its actual size, it could also be the spring that holds the ash tray closed.
08-27-2010, 11:37 PM | #6 |
it is for the vent for fresh air like on the lmc page. it attaches to the vent flap and a metal piece.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
08-31-2010, 08:04 PM | #7 |
It looks like the spring that is on the little orange gear selector needle in the dash... But that depends on the size, just my opinion...
08-31-2010, 08:10 PM | #8 |
It was for the vent door in the kickpanel on the passenger side. Next time, I will label things when I take them out. Of course, after reassembly it seems not to function with the vacuum contols anymore - fix one thing and break another.
08-31-2010, 08:19 PM | #9 |
i know how that goes! good luck gettingg it all fixed up
