Old 07-31-2010, 12:10 AM   #1
Rideto100
Rideto100's Avatar
71 vs. 69 question
I am brand new to this site and have really been impressed with what I have seen so far, there is some great info on here so I am hoping someone can answer a question for me.
I just purchased a 71 Cheyenne long bed that had been sitting for the last five years. Overall the truck is in great shape and I couldn't pass up the great deal. I had planned on cutting it down into a shortbed; however I just also came into the possession of a 69 shortbed without a bed. The 71 is still a very driveable truck but I want to do a frame off rebuild. I am going to completely rebuild the 69 frame before I start on the body. My question is could I also use the 69 cab in place of the 71 so I can keep driving the 71 as long as possible or are the cabs that much different. From comparing the two I can't see anything that jumps out at me but I know there are people on here having to modify their 69-70's to fit a 71-72 gas pedal.
I know this is a long post but any and all help would be greatly appreciated. The cabs are very similar in shape as in both have very little rust on them.-Jamie
Rideto100 is offline   Reply With Quote
Old 07-31-2010, 12:19 AM   #2
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: 71 vs. 69 question
There is really not much difference. If its going to be a temp transplant, just use the 69 pedal & rod assembly to control the carb.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 07-31-2010, 12:26 AM   #3
Rideto100
Rideto100's Avatar
It would be permanent, not temporary as I would do all the bodywork to the 69 instead of the 71.
Old 07-31-2010, 12:29 AM   #4
leddzepp
Moderator
leddzepp's Avatar
About the only difference in cabs are a high hump or low hump transmission cover....oh and the 72's had the rear view mirror mounted to the windshield, not the roof of the cab. Other than that, I believe they are all the same. Welcome to the board and good luck!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-31-2010, 12:38 AM   #5
ed70
is very serious
ed70's Avatar
do not cut a long bed to a short bed i will cry
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold
1970 C-10 2wd fleetside LB 307 700r4 - sold
1969 C-10 2wd fleetside LB 327 3spd - sold
1969 C-10 2wd fleetside LB 350 th350 - sold
1967 C-10 2wd fleetside LB 250 th400 -project in progress
Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed.
ed70 is offline   Reply With Quote
Old 07-31-2010, 01:22 AM   #6
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
For a purist, the 71 cab has subtle details different than that of a 69'. It depends what you want to do for a restoration. The 71' rear view mirror mounts on a raised pad, and to my knowledge is the only year that this raised area on the cab exists. The 71' will also have a vent by the vin plate in the door jam and not on the 69'. The 71' being a Cheyenne means it has the headliner holes punched in the roof, and the 69' (unless a CST) will not. Like I said, if you don't plan to still make it a 71' Cheyenne, I wouldn't worry about it and use the 69' cab. With using the 69' frame, it wouldn't matter anyways for a stock restoration under the 71'. Good luck with what you decide, sounds like a fun project. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-31-2010, 01:28 AM   #7
travlinman
dont worry about cutting the bed people do it all the time.
i would look at both truck and figure out a plan. if u wanna keep both trucks or redo 1 and have another for parts ? id keep driving the 71 while redoing the 69 until i got to a point where i needed or wanted the 71 parts and start swapping things over. u can sell what u wont need/use and get some money for more parts.
good luck
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 07-31-2010, 09:54 PM   #8
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
The other plus to the 71 is disks up front. Heck with it, just redo one at a time and drive the other!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
