Old 07-31-2010, 02:00 AM   #1
ERASER5
ERASER5's Avatar
14 bolt question
I have seen plenty of 14 bolts diffs, on trucks, with the wheels on. Kinda hard to tell much about the brake setup that way.
Are all the drums or rotor conversions mounted the same way? Or do they differ over the years? Do any 14 bolts have floating drums?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-31-2010, 07:04 AM   #2
LONGHAIR
Re: 14 bolt question
There are later model semi floating 14 bolt rears that do have "slip on" drums, but they are not the same as the "traditional" big 14 bolt. I have never done a disc conversion to a 14 bolt, so I am no help there.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-31-2010, 08:38 AM   #3
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
There are a few places selling disc conversions for the 14 bolt.
I put disc on the back of my mudder. I'm the cheapest guy around so I built the brackets myself and welded them on.Used the same calipers as the front because of no concern for an e brake.
I haven't seen a dual wheel slip on drum but then again there is nothing late model on my place
powerdriver 1958 is offline   Reply With Quote
Old 07-31-2010, 09:22 AM   #4
b454rat
I don't think any older 14ff had slip on drums, but I had one from a 90s that had the slip on drums, and was a full floater. Was off a 3/4 ton, maybe that had something to do with it.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 07-31-2010, 08:38 PM   #5
ERASER5
ERASER5's Avatar
Thanks. Just needed some info.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 08-01-2010, 03:51 AM   #6
Shaffer4
Strange Cousin From The West..
My 14bolt Full Floater is giving me fits atm, trying to replace the wheel seals. It has slide off drums (held on by two screws) I bought 2081 seals and it has 455860 seals on it. From what I've read the '86 and later Full Floaters were available in some applications with slip off drums. But I haven't seen anything about the seal size being different.
Shaffer4 is offline   Reply With Quote
Old 08-01-2010, 04:10 AM   #7
Shaffer4
and upon further review it seems she has a 60 stuffed under her hind side, rather than a 14 bolt... What I get for listening to what other people tell me...
Old 08-02-2010, 02:37 PM   #8
RaysK20
From my view it looks like your rear brake line is touching the exhaust pipe. That might not be a good idea.
RaysK20 is offline   Reply With Quote
Old 08-06-2010, 09:22 PM   #9
Ratpowerd67
ok.....there is actually two kinds of 14 bolts......althogh both have 14 bolts on the cover, one is the heavy duty full floater with a 10 1/2 ring and the other is a semi float c-clip with a 91/2 ring. you can identify the heavy duty version by the 6 bolt patern around the driveshaft yoke. the light duty looks smoth in that area , like any other rear and the drums come off like any other axle....i also have rear disc on my truck and im useing calipers and rotors off a dana 44 front axle and im useing brackets that bolt to the axle flange where the backing plate used to be..........hope this helps.
Ratpowerd67 is offline   Reply With Quote
Old 08-14-2010, 10:15 PM   #10
iroc12valve
on every 14 bolt full floater i've had (5 of them) you have to pull the axle shaft, snap ring, woodruff key, spindle nut, then you can slide the brake drum off.
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
