Old 07-31-2010, 05:04 AM   #1
monza1979
monza1979's Avatar
drive line length, lifted 78
putting on a lift, 4 inch, and my front driveline is to short, what have you guys used? it is a manual trans truck, a 78 with an sm 465. is an auto drive line longer, or do i have to have one made? have not gotten to the rear, what issues will arise there? remedies?
I had the right to remain silent, but i didn't have the ability!
78 chevy swb 4x4 sm465 np205 350 4" lift, ORD flip kit, ORD Ext. brake lines
79 Chevy Monza:current plans, dz 302, 4 speed
69 Pontiac Firebird: 74 s.d. 455 build up, m22 rock crusher
monza1979 is offline   Reply With Quote
Old 08-01-2010, 10:11 PM   #2
bikes&bowties
bikes&bowties's Avatar
Re: drive line length, lifted 78
with a 4 inch lift it shouldnt be to short........ drop the t-case . the little spacers on top of the frame work perfect if you just move them under the frame between the crossmember and frame. that should drop your t-case about 1.5 inches if i recall.. that might help your troubles
bikes&bowties is offline   Reply With Quote
Old 08-01-2010, 11:21 PM   #3
monza1979
monza1979's Avatar
the front will bolt back on, but it is all the way extended. rear is perfect. not the biggest fan of dropping the t-case down any, that was the point in lifting it. anyone know of a similar driveline? i can get conversion u joints if need be.
Old 08-02-2010, 01:26 AM   #4
bikes&bowties
I dont see any other choices then getting one custom built
Old 08-02-2010, 06:08 AM   #5
LONGHAIR
Most of the time, the yokes are different between the 4 speed equipped trucks and the automatics. I'm don't think that they will interchange, so the length difference (if any) would not be a big factor anyway. It would cost more to do any kind of "adapting" than to just get your original re-tubed, and definately be more hassle.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
