Old 07-31-2010, 10:13 AM   #1
blazer2007
anything wrong with this setup?
I,m looking for a simple rear setup and came across this on the site and was wondering if this looked OK.Do you think the bags are to far in.My truck will be 99% in town.I,m not looking for a big step notch, just across the top of the frame is all I need
blazer2007 is offline   Reply With Quote
Old 07-31-2010, 10:39 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: anything wrong with this setup?
It depends on what you are trying to accomplish. What I see that doesn't look right is it has a single leaf, double convulated bags, and they are mounted over the axle. All of those items "work" for a simple package, but they are not the best choice.
Give us more details on what your looking to do. What size tires, how low you want to go. Do you really need a step notch, etc.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-31-2010, 11:02 AM   #3
blazer2007
I have a c notch now but not enough room,maybe 2 inchs from axle to frame.Tires are 31 in tall,front is bagged with no cups with tube a arms coming.I just want to sit level when aired out.
Old 07-31-2010, 12:24 PM   #4
LONGHAIR
With-out some kind of traction bar, you are going to have problems with axle-wrap. The single leaf spring cannot take it. The snapping action is hard on axles, u-joints, etc....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-31-2010, 01:02 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Simple solution is get shorter tires. Beyond that have you looked at the set up tvblazer78 is running on his?
Articles-
"Refining Sierra"
Old 07-31-2010, 01:05 PM   #6
SCOTI
SCOTI's Avatar
^^ Combine that w/the DBL convoluted bags over the axle & you get axle hop under accel/decell w/a possible bumpy ride the remainder of the time because of the position of the bags.
Sleeve type bags are better for on the axle mounting; DBL convoluted bags work better mounted on an arm w/different leverage.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-31-2010, 03:21 PM   #7
blazer2007
I have looked at tv,s setup but no way I can get a bag in there.For wheel hop or axle wrap could I run a caltrac ?
Old 07-31-2010, 03:48 PM   #8
SCOTI
SCOTI's Avatar
You could, but that would be throwing more money @ a still less than stellar arrangement. It would be better to spend more & get more for the spending (CalTracs are around $400 shipped).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-31-2010, 09:23 PM   #9
blazer2007
.It,s on a blazer so I don,t have the luxery of taking the bed off.Found another pic which I like.All I need is the frame width removed so I don,t have to butcher too much of the bed,or would I better off going to a 2 link setup,if thats what it is called,pic # 2 with a panhard or other simple solution without having to fab a whole lot of brackets etc.
Old 07-31-2010, 11:05 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
If it were me, I would start by talking with Nate at Porterbuilt and see how close he is to having his rear system available for a Blazer. If that's not an in your budget, take a look at a Ride Tech universal 4 link.
I have attached pics of the Ride Tech triangulated 4 link that we used on my 82 Blazer. This was not designed for the Blazer wheel base, so consequently there was more rear sway than I felt should have been there.
My plan was to increase the angle of the upper bars to see if it would solve the issue. If not, I would convert it to a parallel bar system and run a panhard bar.
The point of the pics is to show how low it would go with out cutting the floor.
Articles-
"Refining Sierra"
