Old 07-31-2010, 02:16 PM   #1
Super73
Super73's Avatar
Factory Disk brake Caliper Weight??
Does anyone have a caliper from a 67-82 off their truck that would be willing to weigh it. I'm planing on doing some changes for weight purposes and curious to know what I'll be shaving in the caliper. Thanks in advance.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-31-2010, 02:30 PM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: Factory Disk brake Caliper Weight??
regular shipping weight for a front brake caliper is 10.23 lbs
This is a bare caliper, meaning no brake pads, not painted. Hopefully this helps.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-31-2010, 05:58 PM   #3
Super73
Super73's Avatar
Thanks.. I appreciate it..
Any one have a rotor laying around that would be willing to weigh as well?
Old 07-31-2010, 06:29 PM   #4
LONGHAIR
If you are planning upon using stock cast iron parts, I would doubt that there is any weight savings at all.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-31-2010, 09:29 PM   #5
Super73
Super73's Avatar
No sir.. 4th gen rear brakes use the same size rotor yet use alum caliper with steel bracket. The caliper and bracket weighs in at 7.8lbs vs 10.23 which is almost 5lbs for both sides. If I can find a light weight rotor that is 5x5 and bearings that will work with it, might be worth the work. On the other hand I want to put a new frame and mustang 2 front on it, but that is a ways out. If I can shave 30lbs for a couple hundred right now, it is worth it to me.
BTW, this is a race only set up. So please don't freak out...
Old 07-31-2010, 10:42 PM   #6
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
so are you converting your front end to something totally different or retrofitting something to the stock spindle?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-01-2010, 02:34 AM   #7
Super73
Super73's Avatar
I'm in the air on that right now. I have a 67 Camaro spindle I think I can make work by reaming the ball joint holes out slightly and running the parts needed at that point..
Or
Using the truck spindle and finding a bearing that will work with an aftermarket rotor and making mounting plate for the 4th gen caliper..
Or
Holding off completely and building a new frame with a Mustang 2 front and light race brakes to go with it...
It all comes down to money. If I can shave 30lbs for $250, I'll go that route for now. But if not, then I will wait and put that $250 towards the $2000-2500 mustang 2 front set up and shave 150-300lbs with the frame and m2 stuff. The frame is cheap, I have 2x3 ans 2x4 .120 wall sqaure tube.
Old 08-01-2010, 09:02 AM   #8
LONGHAIR
Not freaking out....It just seemed from your original post that you were converting from drum to disk and thinking that there was a big weight savings.
Bad assumption on my part....
Old 08-01-2010, 07:40 PM   #9
Super73
Super73's Avatar
No problem.. The freaking out comment wasn't actually direct towards you It was a general statement as I have seen people get a little worrysome assuming the truck get's used as a daily driver.
Old 08-02-2010, 09:22 PM   #10
SBTork
Garage wrench
SBTork's Avatar
Front brake rotor weight is 29.4 lbs each
-Adam
