throttle linkage ??
i just did a str8 6 to 350 swap and i was wondering what u guys did for a throttle linkage because the str8 6 linkage isnt very good the pedal half way down is full speed on the 350 so its kinda hard to drive. i was wondering what u guys did so it drives right
1978 c10 stepside |
Who's got steelies?
![]() Join Date: Feb 2006
Re: throttle linkage ??
If you've got a rod linkage, you should be able to adjust the rod length to get the gas pedal to feel right. I think you can get a generic throttle cable at an auto parts store if you got the 71-72 setup that you can adjust.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Complelty off topic and Im sorry but what color is your paint? Like the name or code, I like the light blue like that but cant find the name or code. Thanks.
Gone to greener pastures
![]() Join Date: May 2007
We cut a chunk (don't remember how much
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
its a vw color i dont remember whats its called i bought it like that
1978 c10 stepside |
is there some one on here that makes that cable linkage cause the rod on dont work i want to switch to the cable but i dont know how hard it is
1978 c10 stepside |
Cruzin
i used a lokar cable on my 71 no problem
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
1978 c10 stepside |
Pictures? I think you may have to increase the length of the vertical part of the linkage and/or lengthen the arm on the carb (or at least the point at which the linkage attaches to it).
The truck is going to exhaust today I'll snap a pic if I remember if not when I get it back
1978 c10 stepside |
I used heim joints and threaded rod. It's smooth and doesn't bind like a conventional rod setup.
![]() You could also just go ahead and change to a 71-72 cable setup with THIS.
