Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-31-2010, 03:20 PM   #1
gene_ensor
gene_ensor's Avatar
15 x 14 Rims 10" back spacing?
Hello again friends. Can someone provide a good source for low budget 15x14 rims with custom back spacing? Currently my axles are 6 lug 1969 vintage trailing arm. Any additional comments on clearances, best brake line re-route fix, and e-brake setup would be appreciated. I would also entertain some mockup rims prior to blowing the budget on a narrowed axle. Thanks.
Info collected via multiple threads:
Wheel mating surface to WMS 12 bolts
1967-1970 62" 6 bolt (conversion to 5 bolt CPP, ECE or Summit)
1971-1972 63.5" 5 bolt
1973-? unknown 5 bolt
User width rim / tire / back spacing
prostreetC-10 62" 15x14 18.5 8.75 bs
SCOTI 62" 15x14 18.5 9.50 bs
.............. 15x14 10.00 bs possible
Comment: Remove the rear bumpstop + bracket on the outside of the frame. Cut the bedfloor to clear & stretch those tubs! On a coil/trailing-arm truck you can fit a 15x14" wheel w/10" of back spacing & not hit the frame rail. The wheel tubs in the bed only need to be enlarged as big as the tire. I had Mickey Thompson 31x18.5x15's on widened/custom offset corvette ralleys w/the above spacing on my 67 short fleet w/a stock length truck 12bolt rear end. This all depends on the relationship between rear-end & trailing arms not being altered (no lowering blocks).
1968SWBBigBlock 62"? 15x14.5 8.75 bs
Comment: I am running a standard 1968 width axle, using 18.5" wide Hoosier pro street radials Floor of the bed is cut back flush with the frame rail Wheel tubs widened accordingly I changed the springs over to a non tapered style similar to what is on the front suspension - you will not have enough room for a tapered spring (if you do not mind I would suggest just welding on spring perch's and using coil over set closer to the center of the truck, adjustable for ride height and dampening) Wheels are -offset by 8.75" (I would only go 8.25" next time - I think I can push 1/2" + into the wheel well without issue but I am to close to the ebrake line and had to build brackets to pull them away from the wheels to keep them from rubbing
70C10 Custom 29x18.5x15 Hoosiers 3.5"bs
Comment: 1.5" clearance on the frame rails and 1" clearance on the outer fender lip.
QKENUF4U 63.5" 15x14 rims w/ 10" bs 31x18.5x15 tires
Comment: stock frame/suspension only problem i ran into was balancing the tires. The machines don’t have a long enough arm.. could balance on a bubble balancer though.
gene_ensor is offline   Reply With Quote
backspacing, drag, prostreet
