Old 07-31-2010, 05:52 PM   #1
Psycho71
Psycho71's Avatar
Help ID my T-case?
My transfer case out of an '85 3/4 ton brub. Date stamps all read 84&85, so I'm thinking it's original. But it does have excess amounts of gasket sealer in places, so I'm guessing it's been into.
Found two large casting numbers. First is C-15085, second one is C-15164. Don't remember right off which one is on the front of the t-case and which was on the rear, but they were each on a different half of the case.
It does have "NP" in a couple of places. but no obvious "203, 205, or 208" on it anywhere.
Thanks for any help. If this doesn't get it, then I'll take and post some pics of it.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 07-31-2010, 06:07 PM   #2
Psycho71
Psycho71's Avatar
Re: Help ID my T-case?
OK, well I found the ID tag, didn't know it would be on a tag. But I scraped the black paint off and found the 208C on it.
So now that's figured out..Anything particular I should know about this case? Any unusual weaknesses? Is it a POS or a decent transfer case?
It's mated to a TH400 transmission if that makes any difference.
Thanks,
Jay
Old 07-31-2010, 08:22 PM   #3
Fursphere
Without splitting the case, there isn't much you can tell about the condition its in.
1966 C10 Panel (3/4 Ton 4x4 Conversion)
2001 K1500 Silverado
Fursphere is offline   Reply With Quote
Old 07-31-2010, 08:24 PM   #4
bikes&bowties
bikes&bowties's Avatar
not a pos but its nothing like an np205.. aluminum and chain driven
bikes&bowties is offline   Reply With Quote
Old 08-06-2010, 09:37 PM   #5
Ratpowerd67
i run 44s with a sm465 and a 208 and abuse the crap out of it. ive busted 3 cases, but after that i custom made a heavy bracket that bolts to the side of my 4speed and then to the side of my 208. ever sence then,,,no breakage....the bouncing leaverage in the mud pits where snaping the cases in half.
Ratpowerd67 is offline   Reply With Quote
Old 08-07-2010, 11:13 AM   #6
Psycho71
Psycho71's Avatar
Do you have any pics of the bracket you made. I'd be curious to see it so I might could imitate it somehow.
Old 08-14-2010, 10:08 PM   #7
iroc12valve
Keep in mind that th400/np208 is the same drivetrain the US Army used on all M1008.
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
Old 08-18-2010, 06:23 PM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea they aren't a bad tcase. I would be interested in seeing some pics of that bracket as well Rat if you have any that would be sweet!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-19-2010, 08:39 PM   #9
Ratpowerd67
i almost forgot to post, the truck is dirty....sorry
Old 08-19-2010, 08:42 PM   #10
Ratpowerd67
oops, the third pic is wrong....oh well
