Old 07-31-2010, 08:49 PM   #1
rebel01
Serpentine Swap Questions
Hey guys, I was able to answer almost all of my questions reading old posts, but I'm left with 3 unanswered.
My truck is a 71 with the original 350. The serpentine setup I have is off of a 4.3 & is the aluminum bracket version.
Question 1) What upper & lower radiator hoses do I need?
Question 2) Will I need to swap thermostat housings?
Question 3) Do I need to run a later model harmonic balancer with this setup?
Thanks for any help, so far this board has been a great resource for me!
Thanks, Jonathan
71 C10 Cheyenne 350/350 LWB
Vices= cold beer, fast Mustangs, & old Chevy Trucks
rebel01 is offline   Reply With Quote
Old 07-31-2010, 08:59 PM   #2
Alex Hayley
Re: Serpentine Swap Questions
1) I took the easy way out and used something like this: http://www.summitracing.com/parts/MRG-11010C/ . I thought it would look cheap but I kind of like it.
2) Not necessarily. See if you can find a rad hose that fits the existing thermostat housing.
3) No. As long as the crank pulley bolts to existing harmonic damper and lines up correctly with the other pulleys you are fine.
Alex Hayley is offline   Reply With Quote
Old 07-31-2010, 09:32 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
I made up a hose for mine from the truck I got it from and the original using a step down exhaust pipe. I used the stat housing for the truck I got it off of, a 91 and I used the original balancer.
dwcsr is offline   Reply With Quote
Old 07-31-2010, 11:00 PM   #4
Sammy
Thermo housing from the doner a serp setup and the hose. If you didn't grab it you can get a 45 swivel thermo with the O ring. And a upper hose from a parts store that fits a 93 or 94 3/4 T P/U GMC will work and probally others too but I know that year n truck will work. The lower hose is more of a crap shoot depending on where your engine is mounted.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-31-2010, 11:24 PM   #5
rebel01
Sweet! Thanks for all the info folks. I still have the donor motor in the back of the truck, so I'll grab the t-stat housing off it.
@ Sammy - the engine is in the front location, from what I can tell, if that'll help narrow it down on the lower hose.
Thanks, Jonathan
Old 08-01-2010, 12:10 AM   #6
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
lower hose is gonna be from a 84 Chevy burd with 454. just did it myself!
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 08-01-2010, 04:59 AM   #7
cdowns
cdowns's Avatar
make sure you get the reverse rotation waterpump that is needed
Old 08-01-2010, 05:11 AM   #8
btullis99
btullis99's Avatar
x2, very important
btullis99 is offline   Reply With Quote
Old 08-01-2010, 09:30 AM   #9
rebel01
Thanks!
Originally Posted by btullis99 View Post
x2, very important
Absolutely. The one on the donor looked like it was replaced recently, so I pirated it as well.
Thanks, Jonathan
