So, my camaro IFS graft is nearly completed, thanks to the No Limit DVD. That was a huge help! Only lacking the '59 frame horns be welded onto the front of the Camaro sub-frame for front sheet metal/rad support and bumper. I grafted the sub frame a couple of months ago, BUT, I have LOST all of my measurments!!!!!
I was curious if you have generic measurments that most trucks "should" fit into. I recall projecting out level from the brace and having a certain amount of drop. Then, I had measurments straight out to the end of each frame horn and diagonal from driver to passenger and vis-versa. Am I totally screwed here? Do I need to hang the front clip and build to fit or are there generic measurments that these trucks shoud fall into??? Thanks for any help guys!!!
