Old 08-01-2010, 12:57 PM   #1
weircc
weircc's Avatar
BBC frame stands????
went to install motor today i have big block frame stands and i got a set of these motor mounts from jegs for big block and small block applications its just not working out, the motor wont go down far enough to get bolts started. i seen some tubular style frame mounts awhile back on here and im wondering if i should go that route.
weircc is offline   Reply With Quote
Old 08-01-2010, 02:11 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: BBC frame stands????
what year are your BB frame stands? PICS?
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 08-01-2010, 02:32 PM   #3
weircc
weircc's Avatar
they look just like these
Old 08-01-2010, 03:16 PM   #4
Newtz67
Newtz67's Avatar
Feel free to check out my mounts. They make dropping the motor in so much easier!
Newtz67 is offline   Reply With Quote
Old 08-01-2010, 03:57 PM   #5
weircc
weircc's Avatar
[QUOTE=Newtz67;4117585]Feel free to check out my mounts. They make dropping the motor in so much easier![/
those were the exact ones i was looking at did you like them was it as easy as it looked???
Old 08-01-2010, 03:59 PM   #6
weircc
weircc's Avatar
does anybody know if these will work with a big block
http://www.classicperform.com/Store/...ck/6372MPS.htm
Old 08-01-2010, 04:05 PM   #7
Newtz67
Newtz67's Avatar
[quote=weircc;4117646]
Yes, they make the install so much easier. If you have a 67 frame, you'll have to notch it, if it's 68 or newer, they should bolt right in.
Old 08-01-2010, 04:06 PM   #8
Livrat
Member #1049
Livrat's Avatar
From your avatar it looks like your truck is a 67... if so, 67 frames need to be trimmed at the top for the BB stands to sit correctly.. If you have access to any trucks from 68-72 take a peek at the top frame rail where the stand bolt on and you will see the needed mod to the 67
Livrat is offline   Reply With Quote
Old 08-01-2010, 04:46 PM   #9
weircc
weircc's Avatar
its a 70 with 67 front clip and shaved marker lights
