Old 08-01-2010, 01:51 PM   #1
eyebuzz
Licensed driver
eyebuzz's Avatar
Neutral Safety Switch - Reverse Lights
Hi All,
My reverse lights come on in Neutral. (72 Suburban)
1) Looks like an easy fix - looks like I loosen the bolts to the neutral safety switch at the top of the steering column - just before it enters the engine compartment - and move the assembly around til the back up lights come on - IS THIS CORRECT? By moving the neutral safety switch (there is room to move for the brackets) am I also messing with the starting in P and N ('cause that works fine - just the reverse lights are off).
2) If the above is true - it looks really hard to get a wrench in there to loosen the bolts - anyone done this with common tools - or do I need something special?
Thanks....new here to the board (and to the world of 1972 Suburbans) and really appreciate all that I've learned and read so far.
eyebuzz is offline   Reply With Quote
backup lights, neutral safety switch
