Old 08-01-2010, 03:04 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
Question Bed mounting??
My '73 has a roached bondo sculpture for a bed. Im going to look at one from a '86. Do the two bolt/mount the same?
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 08-01-2010, 03:53 PM   #2
texasfunk
texasfunk's Avatar
Re: Bed mounting??
they should be the same,all the beds are the same from 73-87
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 08-01-2010, 04:44 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Bed mounting??
Major differences are in the fuel filler area, and tailgate hinges. Mounting locations should be all the same.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-01-2010, 06:44 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Bed mounting??
Thats what i thought. thanks
Old 08-01-2010, 08:16 PM   #5
bigblock73
yeller
bigblock73's Avatar
Re: Bed mounting??
Not true.
Fuel doors changed, and the ribs in the bed changed dimensions slightly (older models vs newer, unsure of the exact year though).
Otherwise, they should be identical.
bigblock73 is offline   Reply With Quote
Old 08-01-2010, 08:53 PM   #6
texasfunk
texasfunk's Avatar
Re: Bed mounting??
Sorry, should've elaborated, I was just talking about the mounting to the frame
1986 Monte Carlo SS
1955 Chevy Bel Air
Old 08-01-2010, 10:17 PM   #7
ray_mcavoy
Re: Bed mounting??
Actually, I have noticed a difference in the mounting bolt locations on some 73-87 longbed trucks.
It's the 2nd set of bolts back from the cab. Most trucks have these bolts passing through the 3rd bed cross sill back from the cab. They're lined up with the frame crossmember at the spring hangers so extra long bolts that pass all the way down through the frame are used for easy access to the nuts.
Some trucks have that 2nd set of bolts up closer to the cab. Passing through the 2nd bed cross sill back from the cab. These ones use shorter bolts (like the other 6) that only go through the top rail of the frame. Trucks I've seen with this bed bolt arrangement have all been longbed 4x4's.
ray_mcavoy is offline   Reply With Quote
Old 08-02-2010, 12:57 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Bed mounting??
If my USB port would cooperate i could download pics But i brought home a decent 180$ bed...
