Old 08-01-2010, 03:29 PM   #1
Legolas894
Chemist under the hood...
Legolas894's Avatar
New Quadrajet 4MV Carb-Need help
I found an identical (by number-17058213) quadrajet carb in great shape (divorced choke and all). Got a problem. The old carb had a direct linkage to the throttle pedal. This one can't accomodate the linkage. Is there an adaptor or do I have to fabricate something. Pictures included.
Truck runs great (just can't use the gas pedal).
Thanks!
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 08-01-2010, 03:57 PM   #2
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: New Quadrajet 4MV Carb-Need help
If you carefully take the throttle body off the bottom of the carb (you may have to undo a linkage), you can drill out the stud on the throttle lever so that you'll have a hole to put the rod linkage.
Or, for about $10-15 plus ship, Cliff Ruggles at Cliff's Performance http://www.cliffshighperformance.com/index.html can actually attach the throttle lever off your old carb onto the new one.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 08-01-2010, 08:18 PM   #3
willys72fleetside
willys72fleetside's Avatar
You can swap out the entire throttle plate section (if all the holes match), don't try to remove the screws that are holding the butterfies on to the shaft because they will break.
A USED TRUCK IS A LOVED TRUCK!
willys72fleetside is offline   Reply With Quote
Old 08-01-2010, 10:17 PM   #4
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
swap the base plates. Check the well plugs while you are there, they may be leaking.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 08-01-2010, 11:03 PM   #5
Legolas894
Legolas894's Avatar
So, I would be taking the bottom off the old carb and putting it on the new one. That's a good idea. Everything should match since the carb is the same model. I was hoping there was a jig or adapter for the solid linkage.
I've got it wired together now so I can drive it but I'll have a look at taking the bottom of the old one to see how much work that is.
Thanks for the replies.
Current fleet:
Old 08-02-2010, 01:12 PM   #6
Legolas894
Legolas894's Avatar
I took the base plate of the old carb and when I looked at the new carb, there were some differences which worried me a little. So, I Macgivered a piece of metal and a drilled a few holes and I'm all set now.
Thanks for the help.
Current fleet:
