08-01-2010, 04:22 PM | #1 |
rear end questions
Two quick questions for you guys, I'm rebuilding my rear end. Is this as far as the pinion oil seal goes in? This is where the previous one seated. The lip is about 3/32" from seating flush with the carrier.
Also do the axle bearings need to be greased initially? My repair manual doesn't specify. Thanks. Dan
1970 Chevy LWB - 305/350 In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's. |
08-01-2010, 07:28 PM | #2 | |
Re: rear end questions
That does not look right, are you sure that it's the same as the one that came out?
The term "rebuilding" scares me a little. How far have you taken this apart?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
08-01-2010, 08:13 PM | #3 |
It's the exactly the same as the one I took out and is seated the same as the one I took out. I didn't think it looked right so that's why I asked. I did not do anything to the pinion bearings.
I guess rebuilding is a strong word. I just replaced the axle bearings, oil seals and the pinion seal.
1970 Chevy LWB - 305/350 In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's. Last edited by swierker; 08-01-2010 at 08:13 PM. |
08-01-2010, 08:27 PM | #4 |
Mine sits right up to the housing.Might want to take it out and clean out the the housing the seal sits in.
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
