![]() Join Date: Feb 2001
TH400 Kick Down Switch...where to buy?
I need a replacement switch...I searched some of our Vendor sites w/o any success so maybe I am a lame searcher or these are not easily available. I want to stay stock. Leads?
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 08-01-2010 at 04:34 PM. |
Re: TH400 Kick Down Switch...where to buy?
gm part num 1242101 they are around $25.00 or less just do a search on the part number
This is where I got mine it was about $40 http://www.transmissioncenter.net/35...erformance.htm
Its item 79 toward the bottom of the page
69 Chevy 4x4 383 Power ![]() |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Im running the lokar unit or at least its installed on the truck have not drove it yet so I cannot say how it performs but its there..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
The unit you need for your 70 is the switch located out next to the carb. The cheaper version is the one that mounts inside and operates off the 71-72 gas pedel. I have the switch off of my 68, but you would need the wiring harness and some of the small parts that are available through Rick's first generation as well as others (you need to look at impala, camaro and chevelle parts as many of the parts are the same as the truck in the engine compartment). I can check mine and make sure it is ok, but figure $125 shipped if it is good.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Thanks for the info!
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
