Active Member
![]() Join Date: Jul 2007
Question on cost of gas tank... (mine is leaking)
For the last few months I've been noticing a very strong smell of gasoline in my truck. At first I thought it was just the gas cap venting and some of the fumes going into the truck in this hot weather, but it's gotten so bad lately that I dug a little deeper.
I cleaned the bottom off and found a tiny little pin hole. It's so small I missed it the first time I checked. I looked at the cost of tanks and found they cost between $150 to over $200. What is the difference in the tank that there is such a wide cost margin? |
#2 | |
Re: Question on cost of gas tank... (mine is leaking)
Grandpa in the rustmobile...
too bad your not closer,I think the po put a new tank in my truck i took it out for blazer tank id give it to ya if ya were in drivin distance
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
just me... but if mine starts leaking I would take the opportunity and relocate to a rear or bed mounted tank.. but Im a man always looking for an excuse to make more work for myself.
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED! ![]() ![]() 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I think Id just relocate with a blazer tank.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Active Member
#7 | |
Not saying it would be better. some companies sell the exact same tank for more money. If you buy a Quanta tank you will pay more cause the are made in north america. They are about the best. The ones made over seas all range in prices depending on the store thats selling them. Just depends on how much overhead they have etc. |
#8 | |
Active Member
Do you know if Quanta's made the same or do they use better metal? |
Junior Member
You could do a temporary repair if you need to drive the trunk until you get a new tank.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
http://www.gastankrenu.com/loc/tx.htm
I am not for sure if this is close to you but our shop in MN. uses this company many times and i just got a estimate on mine for $100.00 to $125.00 to repair clean and seal with a lifetime warranty.
Fuzzy |
#11 | |
Active Member
Rottenwood Garage Member
Contact several of the guys in your area that scrap them out...someone will have one. I had a pin hole in one of mine about 8 years ago and didnt have the funds to replace it.....I JB welded it and it lasted about 7 years before it started leaking from a different location. I have also JB welded one of my Suburban tanks and it held untill I replaced it many years later.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#13 |
I jb welded mine and it lasted about a year. Im in East Texas and you can have mine if you come get it. Needs to be patched but if you want it you can have it. I put in a blazer tank in mine. If you clean the tank out, you can take it to a shop to get it patched pretty cheap.
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
#14 |
![]() Join Date: Nov 2004
I'd personally feel better installing a new tank over a 40+ year old one that could have all sorts of scaling and flaking rust going on inside it. At leat with a new one, you'll get a clean tank with another 40 years befere it will crap out.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#15 |
Active Member
Thanks for the offers of free tanks guys. I actually have another one that I took out of my 69 Chevy and may use it for now. I'll probably have it cleaned clean and coated internally.
#16 |
Take a flash light and look down in it....I have only ever seen 2 types.....bad and good. They either are rusted up or they are fine. You will know as soon as you shine the light in it if it is goog.I try to use 2 fule filter on all mine anyway.
