08-01-2010, 07:28 PM | #1 |
C20 Spindle Swap
I searched around but couldn't get a definite answer. I have a 1964 Chevy C20 and I have a complete 5 lug disk swap from a 1972 Chevy. The issue is should I be installing 1972 1/2 ton ball joints and tie rods or 1964 1/2 ton ball joints. I know most people recommendation is to swap all the control arms but I have buckets for bags welded into these arms and don't want to loose that, so much time and money down the drain if I was to swap them out. Anybody have any ideas here?
08-01-2010, 09:21 PM | #2 |
Resistance is Futile
Re: C20 Spindle Swap
Your balljoints should match your spindles, IIRC. I dont know if the b/j will work in the 3/4 ton arm, however. I seem to remember reading that the a-arms have different size for C10 versus C20.
There are a few on here that know for sure. Cap't Fab will probably chime in at some point.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
08-01-2010, 09:27 PM | #3 | |
08-01-2010, 09:51 PM | #4 |
There was a disc brake reference thread that had a ton of info about suspension stuff. Maybe someone can pull it up...I dont keep threads.
08-02-2010, 01:08 AM | #5 |
60-66 Nut
The balljoint holes in the C20 arms are larger than the C10 balljoints. I believe you could do this conversion using the spindles, rotors, calipers, balljoints, etc from a '88-'98 1500 series truck. The one drawback there is you will have metric wheel studs on the front. Otherwise you will have to change the lower control arms.
08-02-2010, 03:04 PM | #6 |
Well that's just not going to work. I've researched all over and it looks like several people in 67-72 gen have reamed out the opening on the spindle. Is 1.5" per foot the right reamer?
08-02-2010, 08:17 PM | #7 |
08-03-2010, 01:08 AM | #8 |
60-66 Nut
I do know that the tie rods and pitman arm are 1.5" per foot taper, and I'm fairly certain that the ball joints are as well. I bought a 1.5" per foot reamer on ebay from the manufacturer. The sellers name is Xcutt I believe.
08-03-2010, 01:19 AM | #9 |
Contact Stan at Early Classic he's the man he will have everything you need.
link--- www.earlyclassic.com |
08-03-2010, 03:16 PM | #10 | ||
08-03-2010, 03:50 PM | #11 |
Doin' it live!
I've considered biting the bullet for the C20 guys too but in a different way. If i could ever get something else to drive I was going to put the 64 C20 on stands and take the thing a part and take the ball joints to Checker/Autozone/etc and see if any other ball joints, like the '98s match. If so that would be huge jump forward. The only thing better would be if the A arms from the 98 would bolt right up to the 64 C20 xmember... maybe I'll have to try that too.
Kinda hard to try stuff when its your daily!
-Panelrodder 1953 GMC Panel truck - 'Curly' 1961 Chevy Suburban - 'Larry' - Sold 2005 Harley Sportster - 'Shemp' |
08-03-2010, 04:28 PM | #12 | |
