Old 08-01-2010, 11:09 PM   #1
dmartin1
dmartin1's Avatar
door panel/power lock removal.
i cant find this anywhere,maybe i suck at searching.
but i got the window crank removed with a paper clip and all screws removed,i just dont know what else there is to do to remove these?do i have to remove the power lock assembly thing?how?
please helpp.
a description on steps how to get this sucker off would be GREAT
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 08-01-2010, 11:13 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: door panel/power lock removal.
the lock nob screws on. is the door panel loose at all
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-02-2010, 04:02 AM   #3
dmartin1
dmartin1's Avatar
yes the entire panel is loose,the lock knob by the glass is unscrewed,but the powerlock button area and around like thedoor open handle seems to be like screwed on tight or something.
idk how that entire power lock button assembly comes off and stuff?
65 nova
And more
Old 08-02-2010, 10:11 PM   #4
6772fan
Active Member
6772fan's Avatar
It's been a while, but I believe there is a "hidden" screw behind the arm rest pad and the outer portions of the door panel have plastic clips that you just have to gently tug outwards to pull them out. then pull up and out on the door panel for complete removal. For the power window and lock switches, they have enough harness wire behind the door panel so that you can pull the panel off a few inches and reach behind. There you will find the connectors which you can remove from the back of the switches.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
