Old 08-02-2010, 01:21 AM   #1
CenValyCali
Pics of bed mounted to frame?
Can I get a few pictures of the way these beds are mounted to the frames? Thanks
CenValyCali is offline   Reply With Quote
Old 08-02-2010, 07:45 AM   #2
lakeroadster
Re: Pics of bed mounted to frame?
There are (8) bolts holding the bed to the frame.
(2) at the back that go through brackets that are welded to the rear crossmember (the crossmember under the tailgate) these bolt through the top of the frame.
(2) at the crossmember near the back, these bolt through the frame.
There are (2) crossmembers toward the front of the bed that have (2) bolts in each crossmember that bolt through brackets that are on the frame.
Last edited by lakeroadster; 08-03-2010 at 05:06 PM. Reason: Malibob set me straight, I forgot the back crossmember
lakeroadster is offline   Reply With Quote
Old 08-02-2010, 10:36 AM   #3
Malibob
Malibob's Avatar
For stock there are 8. Very similar to the pic above (2 where the gas tank is located on John's pics).
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 08-02-2010, 11:22 AM   #4
lakeroadster
Oops, forgot about those, thanks Bob. I updated my original post.
Old 08-02-2010, 12:02 PM   #5
creep
Registered Loser
creep's Avatar
If you have a long bed there a 12 bolts. The extra 4 bolts dont go through the bed floor, they only go through the bottom of the 2 extra cross sills (1 between the 2 front sills and 1 between the 2 rear sills) and through the frame.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
