Old 08-02-2010, 02:11 PM   #1
68 short step
power steering gear box help
does anyone know what size fittings are on gear box of a 84 1/2ton 2wd? i thought they were inverted flare, like the earlier style gear boxes, but they are metric, with o-rings instead...
68 short step is offline   Reply With Quote
Old 08-03-2010, 02:44 PM   #2
68 short step
Re: power steering gear box help
ttt
Old 08-05-2010, 11:29 PM   #3
80SPORT
80SPORT's Avatar
change up was 1980 ...79 down had the old style fittings
80SPORT is offline   Reply With Quote
Old 08-06-2010, 03:44 PM   #4
68 short step
do you know the size of fittings they are?
Old 08-06-2010, 03:55 PM   #5
ericcasas
ericcasas's Avatar
Are you talking about the supply line (pressurized fitted line) or the return line?
ericcasas is offline   Reply With Quote
Old 08-06-2010, 07:10 PM   #6
68 short step
The biggr of the 2
Old 08-06-2010, 08:44 PM   #7
ericcasas
ericcasas's Avatar
I went to Advance Auto parts and they had the entire hose in-stock. One side has a bigger fitting than the other. The one that goes into the steering box is the smaller of the two. The part was $17 bucks. That's your best bet rather than fiddling with an old one. That line has to hold a lot of pressure.
-E
Old 08-10-2010, 11:39 PM   #8
68 short step
18mm x 1.5 o ring, is the correct size. The return is 16 mm x 1.5 o ring.
