08-02-2010, 02:13 PM | #1 |
fuel sending unit interchage??
will a sending unit from a 87 fuel tank work in a 84 fuel tank?
the reason is i want to use a intank pump, with the 84 tank. Last edited by 68 short step; 08-03-2010 at 02:43 PM. |
08-03-2010, 02:43 PM | #2 |
Re: fuel sending unit interchage??
ttt, anyone????
08-03-2010, 02:45 PM | #3 |
LSX addict
yes, id get an '87 tank too tho. it has a pan in it to keep from starving the pump when the fuel is sloshing around.
08-03-2010, 03:11 PM | #4 |
Formerly- 1972SuperCheyenne
It will directly interchange. The 87 tank has baffles in the bottom to keep the fuel sloshing from pissing the pump off. If you use the 84 tank and dont let it get less than 1/4 tank I have had good results that way too.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
08-03-2010, 04:31 PM | #5 |
Ok cool,thanks guys
