Ignition Question(s)
I did a little upgrade over the weekend to my pick'm up ('70 c10, 350, 5.7L 4BBL Eldebrock 1406 carb). I replace the HEI with a complete ignition setup - MDS AL6 ignition box, MSD Blaster 2 coil, MSD Pro Billet Distributor, New spark plug wires, new spark plugs (AC Delco R43T).
I set my plugs gapl is set at .45, started it up and it's a rough idle (I have not set the timing yet). The question is did I set the plug gap to large? A friend of mind said I quote " they should be set between .35 to .40 you need some really good fire if the gap is set at .45." I said, I thought the new setup gave really good fire...am I in left field??? ![]()
CWO3, USN, RET When a man's ways please the Lord, He makes even his enemies to be at peace with him.; A man's heart plans his way, But the Lord direct his steps." (Prov 16:7, 9 NKJV) Never look down on anyone unless you are helping them up. SMS. |
Re: Ignition Question(s)
I ran the same set up on a 350. Spark plug gap at .55. Made a big difference in how it ran with the wider gap. Ran way better. Just experiment a bit to find your optimum gap.
Some say that an MSD like yours has enough fire power to weld with!!! Get your buddy to hand onto a sparkplug wire while you crank it. He'll find out about power!!! Last edited by geezer#99; 08-02-2010 at 03:22 PM. |
you could try the MSD techline too//or if you have the instruction sheets it should b in them
You set the gap just right. A variation will not cause a noticable problem. You need to check your wires & make sure they are not crossed. Set the timing. Check for vacuum leaks.
![]() Join Date: Sep 2005
idle will be bad untill timing is set
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
![]() Join Date: Nov 2007
I think your spark plug gap is fine. The standard GM HEI uses that same gap. I would set the timing as mentioned as see how she likes it. I was thinking about upgrading to the same pro billet distributor, but I thought it didnt require the 6al box.
72 C20 Longbed 05 1500 Z71 |
Hope you mean .045
72 k10 swb. 350/th350/np205. Vintage air'd daily driver |
Yep! Just fast typing .045 is what I meant....
You can run a pro billet with coil on top. No need for a box.
I assumed it would, just threw the question out because my friend insist my plugs are gapped wrong....
