6>8 Plugless........
![]() Join Date: Sep 2007
What to do for shoulder harness seat belts?
I am going over my longhorn project trying to get things ready to build it before the white crap flies. I want to make this thing wife and kid safe. I started going through what all this will need for a family to be safe. I decided I am going to add seat belts with lap and shoulder harnesses. I want to build this truck like it could have been ordered from GM even though it never was. So my question is this:, "What is everyone doing for shoulder belt seat belt upgrades that are close to OE style?" Am I better off just buying aftermarket new belts, or is it pretty easy to come up with decent OE shoulder belt set ups? I searched a little on here but haven't seen many OE sets available. Your thoughts and input are appreciated. Thanks Ryan.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Laid Lo
Re: What to do for shoulder harness seat belts?
The belts out of an older "shoebox" S10 look pretty good in these trucks. The reel on the bottom is small and fits nicely where the old belt was.
The holes should be there in the top to bolt in the upper part. Only trouble is finding a decent set at the yards. Personally I put in seats out of a 01 Silverado that have the belts built in.
Semper Fi, Jeff ![]() '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
Here's some pics of the ones I put in my 67 Gmc. Generic ones from LMC.
![]() Join Date: Oct 2009
I put in the LMC belts too; they work OK, but the driver belt rubs on the gas tank unless you do some fancy bracket work. Also you have to pull then out very slowly or they lock up. Eventually I'm going to look for something better
1971 C10 Longbed, 350/TH350 |
I have buckets out of a 03 siverado withthe seat belts in them. Ill have to put some reinforcement strips in the hole locations though
1967custom |
Thanks for the replies guys!
mine are out of a 93 k1500. work great
1970 GMC K1500 1993 Chevy K2500 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Ryan, the dealer installed shoulder harness setup is quite uncommon. Locating a set is fairly hard to do, but they do come up every once in awhile. Like many have chimed in, you make newer model truck belts work. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Registered Cruiser
S10 belts are great if you can find some
I intend to live forever. So far, so good. |
Moderator
![]() Join Date: May 2007
www.gemstreetrods.com
He has the best prices if you want new belts. Has the necessary brackets to avoid what 48Richard describes above, but you will have to have the female ends cut down (an upholstery shop can do this) as I believe is the case with all of these aftermarket belts. They are the same brand that LMC and other major suppliers carry, but his cost is much less. If I had to do it again, I would probably go with S-10 belts. |
I am a Referee of life.
Just a reminder,the original shoulder belts are 40 years old.The chances of them being deteriorated are huge.They probably wouldn't be safe unless you rewebbed tham.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
I figured that after I typed it. But you never know what some of these guys are digging up for NOS OE parts lately.
#13 |
*** That's interesting ***
Does anyone have good pics of the "uncommon" factory shoulder belts and how they work? I want to know what they look like in case they come up somewhere. I have original GM lap belts now but would like to upgrade with shoulder belts as well (while trying to keep it looking stock and period correct). Does the retractor change? Or is it a lap belt with an adapter for a shoulder belt using some sort of 3-way connection point that many cars used from that era? For example, Mopars commonly reused the standard lap belt but added a shoulder belt that latched in to the lap belt. It was a clunky setup, but it's part of having a car/truck from this era.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
#14 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#15 | |
#16 | |
Moderator
#17 |
i used a set out of a 91 izuzu amigo. they work great. i just had to build mounting brackets.
#18 |
SWB 4x4 Collector
I try to post some pics of my belts in the morning. Trevor
#19 |
Do the S-10 belts create a 3 point connection? And they work with bench seats?
Curry in a Hurry: SB rebuild for my 71 C20 |
#20 |
Does anyone know what S10 model years fit well?
And, do the S10 and 93 K1500 belt setups that have been mentioned come with factory angle brackets to mount to the floor, or do you need to make floor brackets like was mentioned for the 91 Amigo? This is a great thread. I just picked up a 70 C10 and want to add the shoulder belts. I'd at least like to stick with GM parts if possible, so the suggestions here are very helpful. Thanks! |
#21 |
I'm going to try to go to the junk yard this weekend and find something. We'll see.
#22 |
![]() Join Date: Oct 2012
Does anyone have pics to show how these are configured? I recently bought a pair of re-made shoulder belts and I am trying to figure out how they install.
#23 |
Google GM seatbelts and you can order new 3pt belts with GM logos, cost about 300.00
DO NOT PUT YOUR LIFE AHEAD OF MONEY ! Posted via Mobile Device
71 C-20 07 Magnum RT AWD |
#24 |
#25 | |
![]() Join Date: Sep 2012
