Old 02-20-2003, 10:05 PM   #1
Willy Prost
Question 3-speed to 5-speed conversion
I am contemplating swapping out the Saginaw manual 3-speed in my 71 to a Tremec 3550 5-speed manual tranny. I noticed that the input bearing retainer on that transmission is the car size (4 11/16in.) Vs. the truck size (5 1/8in.). I don't want to change the clutch bellhousing to a pre-68 bellhousing. Using search I noticed that a ring can be made to press fit over the bearing retainer to make up the difference.
My questions are:
> How thick should this ring be?
> How tight a press fit is acceptable?
> Any vendors out there making such an item?
> Should the ring be made out of aluminum or steel?
Willy Prost is offline   Reply With Quote
