Old 08-02-2010, 08:39 PM   #1
2500HD
2500HD's Avatar
Electrical help needed
I replaced all of the A/C ducts on Sunday and had the doors open for most of the day. When i finished the truck was slow to start but finally kicked off and ran and idled great. the rest of the day it was slower than normal but started each time. it started this morning and i made a stop before work and it would not start. jumped it off and it would not start later in the day. i drove to my over priced local battery guy and with the truck off and a load on the battery i had less than 10 volts so a new battery was put in and it started and idled higher than normal and very rough. While running it showed 12.4 volts so i bought and installed a voltage requlator. still idled high and rough. set the timing to 8 degrees without much change. While changing the regulator i found a green wire that was capped off coming out of the harness that supplies the regulator. I do not have a volt meter at home so will have to check the current volts latter.
Before changing the battery it idled between 650 and 700 and smooth as butter. It now idles at 850 or 900 and like a plug wire if off.
Anyone have any ideas?
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
Old 08-03-2010, 09:39 AM   #2
2500HD
2500HD's Avatar
Re: Electrical help needed
ttt. Anyone?
Early Classic 4.5/6
Old 08-03-2010, 11:15 AM   #3
BIG69GMC
BIG69GMC's Avatar
did you mess with anything electrical that day??? if you did i would go back and double check it. its obviously somthing you did that day. maybe your pinching a wire now that you messed with the ducts?
BIG69GMC is offline   Reply With Quote
Old 08-03-2010, 11:37 AM   #4
2500HD
2500HD's Avatar
Nothing electrical. After i finished the ducts it started slow because the interior lights were on most of the day. After it started it ran and idled as normal. I was affraid of moving wires around so i was very carefull and was pleased that all guages and lights still worked after the duct install.
Early Classic 4.5/6
Old 08-03-2010, 11:18 AM   #5
Andy4639
Old member
Andy4639's Avatar
Question Re: Electrical help needed
Have you got all the vacuum hoses hooked up correctly? The vacume can cause all kinds of rough idle issues.
Automatic transmission should be around 600 or 700 I think at idle in park.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-03-2010, 11:41 AM   #6
2500HD
2500HD's Avatar
All vacuum lines are hooked up correctly. I replaced all of them one at a time the day before. Again after i was done start and idle where normal. It was idleing at 650 to 700 before the battery problem.
Early Classic 4.5/6
Old 08-03-2010, 11:42 AM   #7
BIG69GMC
BIG69GMC's Avatar
thats weird, have you double check all of your vacuum hoses at your ac ducts? maybe you missed one or did you replace all of them? maybe one came off? i would double check each and everyone of them.
Old 08-03-2010, 12:05 PM   #8
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Do you have regular points still or HEI? The battery dying may have killed your module in the HEI if you have it. Can't say I've ever had a problem like this and if your vacuum lines are good, thats about all I can think of.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-03-2010, 03:19 PM   #9
2500HD
2500HD's Avatar
I guess i could have given all the details
I installed a pertronix, cap, rotor, coil, plugs, plug wires and new vacuum advance all at the smae time. Set the timing and was idling smooth at 650 or so.
three or four days latter i replaced all of the vacuum lines one at a time. Advanced the timing to 10 degrees and idling was smooth at 650 or so.
three or 4 days later is when i replaced the ducts and developed this problem.
Early Classic 4.5/6
Old 08-03-2010, 02:51 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it sounds like another fault showed up at the same time your battery died.
Also, if your only showing 12 volts when running, then you aren't charging either
Old 08-03-2010, 03:25 PM   #11
2500HD
2500HD's Avatar
I would agree. Is there something under the dash that would cause the high and rough idle? Maybe a vacuum line from the A/C controller?
Rodger that.... i have not check the voltage after I installed the new regulator. I will do that today a probably install a reman alt from NAPA just to close the loop.
Early Classic 4.5/6
Last edited by 2500HD; 08-03-2010 at 03:26 PM. Reason: My comment was in the quote section
Old 08-03-2010, 03:38 PM   #12
Longhorn Man
I highly recomend NOT getting a reman'd unit from NAPA. Shops have known to avoid them for years. I would sooner go to a junk yard or get your old one rebuilt. They are all made in china now, and thats a bad thing. Quality is down the crapper. NAPA is where i generally tell ppl to get stuff, but not this.
Old 08-03-2010, 10:51 PM   #13
a.c.1
In all my trials with electrical work, I've learned one important lesson. Bad grounds make funny things happen. I always check, clean and tighten all cables including positive and ground cables at the starter before i start spending money.
a.c.1 is offline   Reply With Quote
Old 08-03-2010, 11:21 PM   #14
mr48chev
mr48chev's Avatar
Wise words there and something that you really need to check before spending any more money.
Check the alternator out and see if it is working right or capable of working right before changing it out.
Is the plug going to the regulator hooked up and is it hooked up correctly?
Is there a specific reason you changed the regulator?
About the only thing that normally goes wrong with the external regulator alternators is that the brushes wear out and don't make good contact with the rings on the rotor. If you short something out on the truck you might blow a diode. Also once in a while a stator will fail but I think that is primarily due to over charging. And the bearings will make noise after a while but they are easy to change too.
Old 08-04-2010, 11:08 AM   #15
2500HD
2500HD's Avatar
I put the plug going to the regulator in just like I removed it. It will actually only go in one way. I changed the regulator because the alternator rebuild shop suggested I do that first and that he really thought that was the problem even after i pointed out that the regulator looked newish. I am going to have my alternator rebuilt I guess.
Early Classic 4.5/6
Old 08-04-2010, 11:03 AM   #16
2500HD
2500HD's Avatar
I had the same thought yesterday. I was checking the ground on the water pump and the eyelet broke off. I thought i had found the problem but after a new ground cable and a new positive end the problem still exists.
i have almost rubbed a bald spot scratching my head.
Early Classic 4.5/6
Old 08-04-2010, 11:16 AM   #17
dirtball
dirtball's Avatar
I would check the condition of the vacuum canisters you just hooked up. One could be torn or leaking. If you disconnect and plug the whole loop for the A/C you could tell if there is a vac. leak in one of the pods. Any chance while the voltage was down you fouled out a spark plug?
Brett
dirtball is offline   Reply With Quote
Old 08-04-2010, 11:33 AM   #18
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Electrical help needed
The alternator doesn't make the truck run rough. It was showing 12.4 at idle right. What did it show when you speed it up? Hold the throttle at about 2 grand and see what it reads. 12.4 at idle ant that bad of voltage. The alternator has to get spinning good before it kicks in and puts out. The alternator doesn't make a idle bad or good. Take a voltmeter and put on the battery and rev it up around 2 grand and see what it tells you.
Bad idle is a vacum leak or distributor problem on the older motors. Grounds can make things happen to.
Old 08-04-2010, 06:22 PM   #19
trusty72
trusty72's Avatar
just some info to help out, a fully charged battery after leveling out has 12.6 volts. when running the alt should put out 13.4 - 14.3. u can eliminate this out of the equation. by the way put a one wire alt on it and forget it.
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 08-04-2010, 07:03 PM   #20
Longhorn Man
one wires are inferior to a 3 wire internally regulated unit
Old 08-04-2010, 07:08 PM   #21
trusty72
trusty72's Avatar
oh ya and 12.3 is half half discharged and 12.0 is dead. this is not running no load of coarse.
1972 super cheyenne
1970 Suburb
Old 08-04-2010, 07:10 PM   #22
trusty72
trusty72's Avatar
That sounds a lot like an opinion to me. I run natural gas compressors 24/7 365 days a year all with delco alternators some 3 wire and some 1 wire. guess which one get changed out more often? 3 wire hands down.
1972 super cheyenne
1970 Suburb
Old 08-05-2010, 07:12 AM   #23
Andy4639
Old member
Andy4639's Avatar
For a GM factory HEI distributor you want to take the resistor wire out of the picture totally. It needs 12 volts all the time. I'm not fimaliar with your setup to say one way or the other.
You can check the voltage at about 2 grand it should be around 13-14 volts.
Old 08-11-2010, 11:20 AM   #24
2500HD
2500HD's Avatar
Got everything worked out.
1. installed new Flame Thrower coil -- did not fix anything
2. installed new Ignitor -- Smoothed out at higer RPM. Still idled like a dragster.
3. Found bad positive wire to the alternator -- did not fix the idle but corrected the charging problem.
4. I noticed a three port vacuum source that had one open port. I thought i recalled a plug on it but it was missing. I also noticed a empty port on the A/C canister so i ran a line from the empty port to the canister. This was the idleing problem. i removed the line i installed and capped it. Idles smooth as butter again. I must have knocked the plug off while removing and installing the distributor.
I think a number of problems came up at the same time.
Next in line is to figure out what is going on with the vacuum canister and why the PO has the heater core by passed. I smell a problem here.
Thanks for the help.
Early Classic 4.5/6
Old 08-11-2010, 12:03 PM   #25
brenthiggins
Man I got to give you credit. Glad you got it straight. Vacuum lines are a pain and I bet you wind up replacing the heater core. Good luck and be careful with the vacuum lines in the dash area.
brenthiggins is offline   Reply With Quote
