Old 02-20-2003, 10:40 PM   #1
minibike
minibike's Avatar
Small Block is a tight fit???
I have plenty of room on the sides, but the front of the engine is a very tight fit. Had to make custom hoses for PS, AC, radiator, etc. This is an LT1 with a 94 Z28 radiator, condesing coils, fans and serpentine setup. Now that all this is done, it's back to blasting and painting.
Greg
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 02-20-2003, 10:41 PM   #2
minibike
minibike's Avatar
Sorry about the angle of the previous pic...
69 SWB
LT1/4L60E
Old 02-20-2003, 10:42 PM   #3
minibike
minibike's Avatar
The good thing, is that the hood will cover all that mess. Here's a shot of the cab...
69 SWB
LT1/4L60E
Old 02-21-2003, 12:21 AM   #4
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
looks good thats probaly a long water pump
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 02-21-2003, 12:37 AM   #5
adamls
Gotta Startem Early
adamls's Avatar
Have you tried moving it back to the I6 mounts. I have heard of people doing this to get more room in the front, little tight at the distributor, and it helps weight ratio.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 02-21-2003, 12:42 AM   #6
minibike
minibike's Avatar
I hadn't thought of that...but too late now. It doesn't have a rear distributor, so that wouldn't be a problem.
69 SWB
LT1/4L60E
Old 02-21-2003, 12:46 AM   #7
mikep
Used to have a truck
mikep's Avatar
Ive got my small block on big block mounts. Different engine than yours I know but I have plenty of forward room. In fact I had to use a long water pump and a 2 inch spacer to get the fan in the big block shroud.
No truck :-(
mikep is offline   Reply With Quote
Old 02-21-2003, 09:54 AM   #8
Myride67c10
Yea I'd say thats a tight fit. Hope you can get to the belt tensioner.
1967 C-10 Use to be Riptide
Myride67c10 is offline   Reply With Quote
Old 02-21-2003, 10:25 AM   #9
crazy longhorn
Fabricate till you "puke"
Yea, thats a little tight.....but what the hell its in there! Did you have a tough time finding the Z28 rad/fans?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-21-2003, 10:48 AM   #10
Frank_Zeller
Frank_Zeller's Avatar
What year Z/28 fans are those?
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 02-21-2003, 06:47 PM   #11
minibike
minibike's Avatar
It's easy to get to the belt tensioner...all you have to do is take out the radiator! Actually, you would have to slide the fans up and out to get to it. Most of the stuff is off a 94 z28, except the engine itself, which is the 95 and up variety. The serpentine system is off of the 94.
69 SWB
LT1/4L60E
Old 02-21-2003, 06:48 PM   #12
minibike
minibike's Avatar
I got most of the stuff from Regal Performance, outside of Dallas. www.lt1s.com
Greg
69 SWB
LT1/4L60E
Old 02-21-2003, 07:06 PM   #13
72c10
72c10's Avatar
I would try to move the ac condencer to the outside of the radiator suport with costom brackets.
72c10 is offline   Reply With Quote
Old 02-21-2003, 07:27 PM   #14
minibike
minibike's Avatar
In hindsight, I would have moved the engine back a couple of inches.
69 SWB
LT1/4L60E
Old 02-22-2003, 01:13 AM   #15
jmil1974
Ain't we cute?
jmil1974's Avatar
Dude, don't sweat it, you're there. That's SUCH a nice motor. I have a buddy with a body shop in Shreveport if it would be of any help. Very nice conversion. Be sure and get us track times and MPG after it's all said and done. Be sure and check out www.camaroz28.com
There you can learn more that you ever wanted to know about the LT1. You'll hate the Opti-puke and manifold leaks but you will LOVE the torque curve and revviness. Not as revvy as an LS1 but I LOOVED mine in the 6spd Z I had. I miss that car . . . .
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
