Old 08-02-2010, 10:53 PM   #1
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Custom Headliner
I am wanting to have a quieter cab and was thinking about a padded cloth headliner like later model trucks have. One that would cover all the metal overhead. I have seen on a TV show a sprayed in and then sculpted with a hot knife type headliner that later was covered with headliner cloth. Another way to make the shell to cover might be fiberglass??? Not sure how that could be done though. What about a junkyard headliner from a late model modified to fit? In all these senarios I still need to figure out how to attach it to the truck roof.
Does anyone have any ideas?
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 08-02-2010, 11:31 PM   #2
pmpski_1
pmpski_1's Avatar
Re: Custom Headliner
I was thinking about putting some sound deadener up there and covering it with one of those highliner speaker systems from LMC. But if that's hard plastic or fiberglass won't some of the sound just echo back at you? I think you're on to something with the headliner cloth.
pmpski_1 is offline   Reply With Quote
Old 08-04-2010, 01:10 PM   #3
drewskiren
drewskiren's Avatar
Anyone????
Drew
Old 08-04-2010, 01:22 PM   #4
john
member #16
john's Avatar
Heres one with a cloth fabric glued on. My upholstery guy does a nice job on them.
john is offline   Reply With Quote
Old 08-04-2010, 02:02 PM   #5
cdowns
cdowns's Avatar
have you done the floor firewall inside doors and in back by gastank yet//i think theres alot more sound that can b reduced in those ares b4 worrying about the roof sound infiltreation
Old 08-04-2010, 02:54 PM   #6
Mondo
Mondo's Avatar
I love that look... but saving it for the last thing done (will be a while). I had a highliner and was going to have it upholstered as it's fiberglass. But that still leaves around the rear window etc..
Mondo is offline   Reply With Quote
Old 08-05-2010, 12:20 AM   #7
pmpski_1
pmpski_1's Avatar
I've done a single door with fatmat so far and there's a noticeable difference. I agree with cdowns.
Old 08-05-2010, 08:22 AM   #8
drewskiren
drewskiren's Avatar
I will be doing EVERYTHING I can for cutting the sound down, extra weatherstripping (Rockrin), b-quiet mat, jute padding, etc. I was wanting a smooth surface for my headliner without the factory ribbing if I just applied directly to the metal, plus I wanted sound deadening between the fabric and the metal somehow. Does anyone have any ideas for sound deadening more than these?
Drew
Old 08-05-2010, 08:36 AM   #9
cdowns
cdowns's Avatar
you can drill holes in the inner roof panel and use a product like lizardskin with a spray wand to coat the outer roof panel
Old 08-05-2010, 01:02 PM   #10
marks1972
marks1972's Avatar
I dont have any pictures anymore but i had my 68 done like this. mine was padded tuck and role with the same fabric my seat and door pannels where done with. looked real nice but sorta made you feel like you where riding in a coffin. only thing is if you dont have good insulation/sound deadner on the fire wall and floor, a headliner aint going make a bit a diffrence in a quieter cab.
Mark
1968 C-10 SWB 307/munci 4spd/411possi 1986-1990
1972 Cheyenne-10 LWB 350/TH350
IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER
U. S. Navy Seabee
"CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard"
marks1972 is offline   Reply With Quote
Old 08-05-2010, 01:27 PM   #11
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I covered the firewall all the way up to the dash, entire floor including down in the cab corners, the back of the cab, the doors (outer skin as well the bottom of the inner part of the door) and under the factory headliner. My truck is amazingly quiet... So much so that with the doors closed and windows rolled up my truck sounds "quiet" running inside the garage even with my loud exhaust exiting out the side. As others have said, I would focus on sound deadening in other areas before you look at covering the entire roof with "fabric".
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 08-06-2010, 01:54 AM   #12
pmpski_1
pmpski_1's Avatar
That's pretty hardcore. Not sure if you're serious or not, but sounds promising if I ever got that hard up for sound deadening. Or insulation.
Old 08-06-2010, 09:25 AM   #13
drewskiren
drewskiren's Avatar
Are you talking about your green truck? It is fantastic!!! Do you have any more interior pics? I love the dash undertray, door panels, and console. what hides behind the small doors in the console, any pics of that? How did you build and attach the under tray? Are you using poppers on the doors or are the handles just hidden from view?
Drew
Old 08-06-2010, 09:41 AM   #14
drewskiren
drewskiren's Avatar
This is a good idea, although from the factory there is a thick wax saturated piece of material sandwiched between the inner and outer metal. The Wax mat is only in the main center section of the roof, about the size of the headliner. It is there to permanently separate the 2 sheets of metal so they would not vibrate against each other. All around the perimeter is a void that you could fill with Body Shultz spray with an undercoating gun and wand.
Drew
Old 08-06-2010, 10:23 AM   #15
67gmcstepside
John, love that cloth look!! He just applied it right to the metal with glue??
67gmcstepside is offline   Reply With Quote
Old 11-01-2010, 09:21 PM   #16
drewskiren
drewskiren's Avatar
I am going to resurrect this question since I have started my build, Young Frankenstein. Since it is a crew cab made from scratch, I need help with a headliner to cover roof braces that are not pretty. I was wanting something smooth and one piece that I could cover in cloth. Any ideas??
Drew
Old 11-01-2010, 11:11 PM   #17
cheyenne shortstep
cheyenne shortstep's Avatar
I had my upholstery guy do a '67 small window I built a few years ago in the same manner as the pic posted by John. He used black Tweed and it looked great, I will be doing this to my '72 Cheyenne but will leave the stock headliner and trim in place.
cheyenne shortstep is offline   Reply With Quote
Old 11-02-2010, 08:48 PM   #18
drewskiren
drewskiren's Avatar
That would be great, except I don't have that pretty inner roof. I need to make the pretty inner roof out of something.
Drew
