Shackle Squeak?
Hey guys,
This last weekend I replaced the bushings in my leafsprings with some stock rubber ones. Well there was no squeak at all, last night I was showing someone and it started squeaking really really loud. I got under the truck and it seems to be coming from the shackle, when I loosen up that bolt the squeak takes longer to notice (pushing up and down on the truck). The shackle has a uthrane type bushing not 100% sure. Is it possible, thats the problem and I should replace that one with rubber ones as well? |
Re: Shackle Squeak?
did you use the lube that came with them?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: Shackle Squeak?
What if Old ones are squeaking
#4 | |
Happy to be here
![]() Join Date: Mar 2000
Re: Shackle Squeak?
I would replace it with a rubber or polygraphite bushing.
Re: Shackle Squeak?
I didnt put the drop shackles on, that was done by the PO so I dont have the lube for them.
I will swap them out this weekend and see if it goes away |
Re: Shackle Squeak?
The black poly bushings have graphite in them... the red one's don't (so i've heard)
Re: Shackle Squeak?
Um, my friend asked me what kind of grease I used for everything, I just went out into the garage....
How bad is wheel bearing grease on rubber? I thought I had swapped the wheel bearing grease out of my gun and put suspension grease in it... I didnt... Do I need to take the truck apart again this weekend and wipe all the wheel bearing grease off and use suspension grease? |
Re: Shackle Squeak?
I used the wheel bearing grease to slide the new bushings in and just put it on the outside of the bushing to slide them into the mounts...
Re: Shackle Squeak?
is it petroleum based vs silcone based? That's the only issue I see, petro might eat through the poly. I'd google it though.
Re: Shackle Squeak?
I just went out and looked at the grease, It says Multi purpose wheel bearing grease and HD chassis grease. It is white lithium based grease, I think I will be alright. If not the bushings were only 40$s so I can buy more if it eats everything away dont really want to take apart the suspension again..
