Old 08-03-2010, 09:49 AM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Step Side Fender Removal
I am trying to remove the step side fenders. I used PB Blast on the nuts inside the fender wall. They all turn - but only so far. Now the Phillips Head Bolt inside the bed is turning. I tried to keep it from turning with a screw driver while using a socket to turn the bolt - no go. I am having some welding repairs done and it would be much easier to weld if I remove the fenders. If I cut the heads off pull the fenders off that way, is new hardware to reattach the fenders available/where?
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 08-03-2010, 10:00 AM   #2
cdowns
cdowns's Avatar
Re: Step Side Fender Removal
i find grinding off the head with a cutoff wheel is the best fastest way to remove fenders and do the same with the bolts holding beds down too
hardware store has nuts and bolts
Old 08-03-2010, 10:08 AM   #3
myoldchevytruck
Thanks for the info
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 08-03-2010, 12:23 PM   #4
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Ace hardware has EVERYTHING!
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 08-03-2010, 01:07 PM   #5
myoldchevytruck
Thanks, there's an ACE right here in the neighborhood
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 08-03-2010, 06:42 PM   #6
lilred67
lilred67's Avatar
i spot welded my bolt head to the bed side so i could remove the nut.
lilred67 is offline   Reply With Quote
