Old 08-03-2010, 11:07 AM   #1
Mikedub82
Mikedub82's Avatar
Wheels
I am trying to find out what size wheels/ offset/ backspace I will need to fit my truck. I am bagging my 66c10 step side and changing to 5 lug in the process. Im using a 5 lug rear end from a 78 c10. My 6 lug wheels would not tuck, i think they are 15x10 wide tires, it may be the tires. Im looking to step up to a 20inch wheel all the way around. Some help would be nice. Thanks
Get Low
Mikedub82 is offline   Reply With Quote
Old 08-04-2010, 02:26 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Wheels
The best and most accurate way to determine your wheel size and backspace is to put the rearend (with all of the brake components, etc.) at ride height and measure, using a straight edge and tape measure.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
