Old 08-03-2010, 12:41 PM   #1
calvin78612
calvin78612's Avatar
5" rear springs
I have a 69 lwb thought about installing 5" drop springs in the rear to start with and then drop the front if needed.My question is will i need to have shock relocation brackets and a different pan hard bar ?
calvin78612 is offline   Reply With Quote
Old 08-03-2010, 12:46 PM   #2
SCOTI
SCOTI's Avatar
Re: 5" rear springs
Yes & yes.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-03-2010, 12:48 PM   #3
calvin78612
Re: 5" rear springs
Thanks for the quick reply.Will i still be able to use my stock shocks ?
Old 08-03-2010, 10:06 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 5" rear springs
No, You can but it'll ride worse..
John
1999 Toyota Tacoma 4x4
Old 08-03-2010, 10:11 PM   #5
project67-stepside
project67-stepside's Avatar
Re: 5" rear springs
contact nate at porterbuilt i just put in his new track and shock relocation kit its awesome and easy
it usual better and faster if u figure it out yourself!!!!
project67-stepside is offline   Reply With Quote
Old 08-03-2010, 11:24 PM   #6
SCOTI
SCOTI's Avatar
Re: 5" rear springs
Maybe, maybe not. It depends on the shocks in use now vs. the possible replacements.
Use 1.5" lowering blocks w/3 or 4" springs & you can get away w/stock length shocks w/some relocators. Anything more than 4" might require shorter drop shocks & relocators.
Check w/CPP, ECE, or Porterbuilt to see if their products will work toward your goals.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
