BMW & ASE Master Certified
Cleared factory GM SideMarker Light
So I decided to spend the extra dollar at the pick-n-pull for a side marker light. I was going to take it apart and refurbish it... and then I noticed some of the yellow coloring was flaking off. A quick trip to the sand blast cabinet at my dads work (super super fine blast media) I sand blasted the back side (inside) of the lense... its not clear, but its not yellow, more like a frosted white. Perfect. I painted some areas black so it would look even better, and the result looks awsome, so now I need to find a passenger side lense.
I am not sure if the new aftermarket are the same way, but this one happened to be an original GM lense. I didnt even have to try hard to seperate the lense from the base as it was already coming apart. Pictures will be up later on tonight. clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Re: Cleared factory GM SideMarker Light
Here are the pictures... I think I will go no chrome, but the edges of the facotry side marker are not crisp... I think I will scuff and rattle can the chrome trim gloss black. What do you guys think?
![]() or ![]() clint
looks good. makes me wonder if i can do the same to the side markers on my 76
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Well what made me think it could be done was thefact the yellow in the lense was peeling from the inside..
i dont have access to a sandblaster so it may not be possible for me to do
Badass
what about paint thinner on there? idk im going to try some things tomorrow i got a few laying around
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Not sure... I was using what I had on hand before I remembered I had access to a sand blaster. I was using throttle body cleaner (there was dark dirt or something in the inside of the lense)... brake clean, small wire brush (like used for golf shoes, but it was stainless steel). Then I went and sandblasted the inside - I held it about a 1 1/2 foot away from the gun becuase I didnt know if it would break the lense... It made the inside dull, which works out great becuase the light seems to be disbursed more evently... theres still the hotspot where the center of the bulb is... maybe I will dab a little black on the tip of the bulb. On the outside of the lense if it did dull it, you could get a dremel tool polisher and polish it right up. I might do that... on the face of the lense where its textured. I had some white crusty stuff in the crevis' and I used some scotch brite pads to remove it, left it a bit dull... as it is now, it looks good... if it were polished... probally look better.
clint
![]() kinda bright outside, but the black with no chrome looked killer.. I will take a night shot tonight. clint
yea, paint thinner will just kind of "burn" the plastic, it will just get hazy, and its not easy to get rid of. lookis good though! wish i had access to a sand blaster!
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
